Shifting problems
Old Sep 15, 2003 | 10:46 AM
mjb240z's Avatar
Default Shifting problems
I have tried the search feature, but did not quite find what I was looking for. I have a 97 Integra LS with 95000 on it. I am having trouble down shifting always & when shifting sometimes. 1st to 2nd is tough but 2nd to 3rd & 3rd to 4th are no big deal. I was thinking master & or slave cylinder problems. I really doubt the syncros are bad personally. I have bled the system, no air & clean, but the problem still persists. The clutch is engaging roughly halfway. There are no leaks in either cylinder which is why I am baffled. What do you guys think it most likely is ? I have called around & the Master costs between $40-100 & the Slave is $16-70. Would like NOT to be guessing w/o some other input. Thanks in advance !!!
Old Sep 15, 2003 | 12:18 PM
Tweakmeister's Avatar
Default Re: Shifting problems (mjb240z)
it's tough to say without further input on exactly what you are "feeling"
Old Sep 15, 2003 | 01:36 PM
NeoGSR's Avatar
Default Re: Shifting problems (Tweakmeister)
is it the stock clutch?
if so, might be time to replace it
Old Sep 15, 2003 | 02:11 PM
mskibbz-T's Avatar
Default Re: Shifting problems (NeoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">is it the stock clutch?
if so, might be time to replace it </TD></TR></TABLE>
Also change your tranny fluid with some genuine Honda MTF... Energy Suspension poly shifter bushings help give a crisper feel to shifts, try em for $15
Old Sep 15, 2003 | 03:55 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Shifting problems (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">
Also change your tranny fluid with some genuine Honda MTF... Energy Suspension poly shifter bushings help give a crisper feel to shifts, try em for $15 </TD></TR></TABLE>
yea, flush your trans, and use Honda MTF.
Should help, unless you have other problems.
Old Sep 15, 2003 | 04:27 PM
BeRightBack's Avatar
I had a problem like this with a car that I recently got rid of. The best thing for you to do is to try flushing your trans and check your cluth
Old Sep 15, 2003 | 05:43 PM
95 geeZer's Avatar
i had the exact same problem with my GSR 2 weeks after i bought it. i would redline 2nd and it wouldn't go into 3rd gear. and when i downshifted i would have to push the clutch in a couple times to get it to go in gear. after i while my clutch felt weaker, and my car shook when i took off in first. i didnt know what it was either and was scared it was the transmission, but it turns out that stock clutches suck, and cant handle much abuse, so i put a clutchmaster in it and that solved everything.
Old Sep 15, 2003 | 05:59 PM
darkstar17's Avatar
Default Re: Shifting problems (95 geeZer)
what more can be said you will have the smoothest transmission with honda mtf if problem presists then it is probablly time for a new clutch. And yes the stock clutch cannot handle hard driving for very long.
Kyle244R948
Aug 7, 2008 10:30 AM
210rudelude
Nov 19, 2006 04:18 PM
Peasonrice
May 5, 2005 04:17 PM
94Accord2c
Apr 12, 2004 07:00 AM
