shift problem
Old Mar 28, 2004 | 12:30 PM
Jaydeep's Avatar
Default shift problem
when i turn on my car try to shift in reverse it is really hard to put in revers. I have 1998 Integra rs it got 73000 miles on it.
guys please help me out here
Thanks
Old Mar 28, 2004 | 12:49 PM
Kendall's Avatar
Any noises, any grinding, does it just feel stiff, or does it feel like something is blocking it, etc? We need details.
Radon_03's Avatar
Default Re: shift problem (Jaydeep)
Does it happen all the time? If its just once in a while, throw the car in second, then go directly to reverse. Sounds dumb, but works for me everytime. Hope that helps.
Old Mar 28, 2004 | 12:55 PM
Kendall's Avatar
Default Re: shift problem (Radon_03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radon_03 &raquo;</TD></TR><TR><TD CLASS="quote">Does it happen all the time? If its just once in a while, throw the car in second, then go directly to reverse. Sounds dumb, but works for me everytime. Hope that helps.</TD></TR></TABLE>
Actually this tecnique works quite well on quite a few different cars. My old EG required this, as did my Porsche.
Old Mar 30, 2004 | 01:50 PM
Jaydeep's Avatar
It happens once in while and its seems like something is blocking it.
Old Mar 30, 2004 | 01:52 PM
mr devious illusions's Avatar
umm.. maybe theres something jamming? like takin off the shift boot and see what's there... ?
Old Mar 30, 2004 | 01:56 PM
95LSB18's Avatar
U might want to change ur tranny oil.
Old Mar 30, 2004 | 01:59 PM
Teggsr2120's Avatar
its normal regardless to what others say
Old Mar 30, 2004 | 02:00 PM
95LSB18's Avatar
Default Re: shift problem (Teggsr2120)
Its true Alot of them to it
Old Mar 30, 2004 | 02:09 PM
ubreak_ubuy's Avatar
Default Re: shift problem (95LSB18)
just throw it into any gear, first, second etc. and back to reverse. happens all the time in my 93 teg, my old 95 civic and even my 94 teg. its very normal. of course after doing that and it still doesnt go into reverse, then u have a problem
Old Mar 30, 2004 | 02:30 PM
xSCTYGx's Avatar
Default Re: shift problem (raceinspired)
yea normally in order for me to get into reverse without grinding, i put it in 4th for a sec, then to reverse..give that a try and see if you still have the problem
Old Mar 30, 2004 | 02:53 PM
escape2me's Avatar
Default Re: shift problem (2Gen91Teg)
Yeah, it's like the 5th to reverse lockout is on. I usually throw it second then back to get it to go. I have also observed that I can simply twist my shift **** a little in either direction and it will slide in...
Old Mar 30, 2004 | 03:24 PM
sp00led's Avatar
Default Re: shift problem (97 GSR)
Ya on my 99 If i have the ebrake on and try to put in reverse when i first go to leave it won't go in. Once i take the ebrake off and slightly roll or shift wheels in either direction it goes right in. But like everyone else said I had a 91 prelude that would almost always make me put it in first then back in to reverse.
Old Mar 30, 2004 | 03:25 PM
Your Epitaph.'s Avatar
///M Power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teggsr2120 &raquo;</TD></TR><TR><TD CLASS="quote">its normal regardless to what others say</TD></TR></TABLE>
Old Mar 30, 2004 | 05:45 PM
beaterman's Avatar
if you are talking about it not going into reverse as soon as you turn on the car and still have the clutch in from starting, then yes it is normal for this to happen. your clutch is not fully engaged. just let it sit for a minute, be patient and then put it into reverse.
Old Mar 30, 2004 | 05:55 PM
riceisnicenv's Avatar
Default Re: shift problem (beaterman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote">just let it sit for a minute, be patient and then put it into reverse.</TD></TR></TABLE>
or do it the quick way, after starting it, put it in neutral, let the clutch out, push it back in then put it in reverse. happens in my 91 hatchback and my moms 98 nissan maxima, its just normal
Anomie
Dec 8, 2007 05:55 PM
kidaniel
Apr 13, 2005 12:12 PM
JOHN WAYNE
Apr 6, 2005 06:45 PM
Vouthanack
May 6, 2004 06:47 PM
freeagent32
Nov 20, 2003 11:21 AM
