Shake under acceleration?
Old Sep 13, 2009 | 08:16 PM
crxstylin's Avatar
Default Shake under acceleration?
My 91 integra LS shakes a lot under full throttle acceleration. I thought it was the drivers side axle or maybe even the tire balance so I took care of both of those. Neither fixed it
Any ideas?
Old Sep 14, 2009 | 06:45 AM
vtec-adykt's Avatar
Default Re: Shake under acceleration?
i bet its one of your engine mounts.. more than likely the rear mount.. check those out first
Old Sep 14, 2009 | 06:57 AM
Russ713's Avatar
dAng!
check mounts and tie rod ends
Old Sep 14, 2009 | 11:19 AM
crxstylin's Avatar
i had the issue before i replaced my mounts and after. All 4 were replaced when i did the one I needed to. I have both new upper outer tie rod ends.
could it be an intermediate (half) shaft, if so is there a way to look and see, like remove the axle and pretend to drive forward with the car on jackstands
EJ1JDM
31
Jun 27, 2011 11:42 AM
makeustruggle
Dec 13, 2008 09:20 PM
JDM H22
Jul 28, 2006 08:16 AM
Jdm BB6
Mar 11, 2006 09:27 AM
tRex99
Nov 19, 2004 04:32 PM
