seat compatibility between DA & DC2
Old Mar 14, 2004 | 10:32 AM
nightrider's Avatar
Default seat compatibility between DA & DC2
As the title says, will seats out of a DC2 bolt right into a DA? TIA.
Old Mar 14, 2004 | 11:35 AM
superthug's Avatar
Default Re: seat compatibility between DA & DC2 (nightrider)
The front gen 3 seats will bolt up but only three out of the four. And you have to do something about the seatbelt.
The rear ones won't work. They're too small.
Old Mar 14, 2004 | 01:31 PM
nightrider's Avatar
Default Re: seat compatibility between DA & DC2 (superthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superthug &raquo;</TD></TR><TR><TD CLASS="quote">The front gen 3 seats will bolt up but only three out of the four. And you have to do something about the seatbelt.
The rear ones won't work. They're too small.</TD></TR></TABLE>
what do i have to do about the seatbelt? i don't understand because my seats have the seatbelt clip integrated with the seat.
Old Mar 14, 2004 | 08:03 PM
superthug's Avatar
you to take the seatbelt motor off your old seats and put it on the new seats. I don't think it would fit, I tried it long time ago. I just converted my auto seatbelts to canadian manual seatbelts. But give it a shot maybe you can mount the motor on it.
Old Mar 14, 2004 | 08:57 PM
Newman's Avatar
New User
3 of the holes barely line up.... 2 holes do w/out any problems but you have to use vice grips to bend the 3rd hole into place. The 4th hole is a good 1.5" away from the original hole so you need to drill & tap/thread a new hole for it. You can bolt the DA seatbelt mechanism onto the DC seat but only using one of the bolt holes, and if you have a wide seat like an ITR Recaro seat, it'll rub against the shifter console since the seat is wider and taller than a stock DA seat, but it still works just fine.
nostreble
Mar 14, 2007 04:29 PM
Skinflute22
Dec 26, 2005 11:54 AM
vteghatch
Mar 8, 2005 11:04 PM
wizzards581
Jul 28, 2004 10:46 PM
GSR901
Mar 4, 2004 10:00 PM
