Screech when turning
Old May 5, 2011 | 06:38 PM
1badcrx's Avatar
Default Screech when turning
It doesnt happen all the time but seems to be more frequent in cooler weather. But when I turn the wheel it makes a loud VERY annoying noise that sounds like metal rubbing metal. It happened in the past and my lower ball joint broke after some time, i replaced it, but that was not the issue. I have also replaced the upper control arm/ball joint, tie rods and i cant figure out what it is. Any help is appreciated.
Old May 5, 2011 | 06:59 PM
TheAsian's Avatar
Default Re: Screech when turning
Jack up your front end and make sure your front end Is tight first off. Look for any areas that look like there has been rubbing. Check the dust shield sway bar end links.
When dose it happen left or right turns. Any recent repairs did anything happen before this started happening
Old May 6, 2011 | 08:41 PM
1badcrx's Avatar
When I jack the car up there is no noise at all when turning the wheels. All bolts seem tight and there is no noticeable wear. I have replaced everything listed above since the noise started... the only thing i haven't is the inner tie rod, which I know is messed up, and plan on replacing soon. I don't think that is causing the noise because it seems to be coming from directly behind the wheel... I plan on taking a deeper look this weekend
Old May 8, 2011 | 06:41 PM
1badcrx's Avatar
jacked the car up today... no noticeable wear. Like I stated before my inner tie rod is in bad shape but I don't really know if that would cause that type of noise. Any chance it could be my shocks or springs?
Old May 8, 2011 | 06:45 PM
Drive 4 fun's Avatar
Dust or splash shield? If bent very close to rotor, then you can get noise in turn and not straight.
Old May 8, 2011 | 06:52 PM
1badcrx's Avatar
I checked that and it all seemed fine.
Old May 8, 2011 | 09:50 PM
turboskratch's Avatar
Sounds like the Power Steering belt to me.
Old May 8, 2011 | 10:13 PM
el crapitan's Avatar
i think i know what you're talking about. my car may have the same problem. happens when stopped and i turn the wheel all the way to the lock on the left side. only happens at the lock. it will, of course, feel like it's coming from the column. but that's only because vibration (sound) will travel through all linkages. i haven't bothered to look and see what it is. i know it's not a joint. i know what those sound like when they're dry.
possibly a rack bushing. or maybe even one of the two knuckles in the steering column. that's my guess without looking. try spraying lube at your suspects one by one. work it in real good. when you find the one that makes the noise cease, replace it.
if you get this resolved before i do, let us know what the culprit was and i'll do the same
good luck
Old May 9, 2011 | 02:07 PM
1badcrx's Avatar
It doesn't necessarily sound like a belt, more like metal on metal and like I said only happens occasionally. I will try the above mentioned methods and see what happens. Thanks for all the input, any more would be appreciated!
Old May 9, 2011 | 06:16 PM
jarmand's Avatar
I work at Honda and one of the techs had the same problem and it was the bearings on top of the strut.
Old May 9, 2011 | 08:38 PM
^^integras don't use mac struts
Old May 12, 2011 | 02:49 PM
1badcrx's Avatar
I thought it may have been the upper pillow ball... but it doesnt seem to be coming from there...
Old May 12, 2011 | 03:32 PM
1998GsRIntegra's Avatar
Not to be rude, but why don't you fix what you know needs to be fixed as opposed to sitting on HT guessing at possible problems.
Have you checked to verify that your wheel bearings are good?
Old May 12, 2011 | 08:14 PM
wheel bearings won't make noise in turns
Old May 13, 2011 | 04:22 PM
1badcrx's Avatar
I appreciate all the info. just replaced almost every part of the suspension and things are seemingly well... for now
Old May 13, 2011 | 04:46 PM
Lol I like how you ended there. Our cars are always a never ending project.
Old May 13, 2011 | 09:05 PM
1badcrx's Avatar
that is the truth
Dualnames
Jun 28, 2015 01:33 PM
Dunks
12
Jan 6, 2014 08:42 AM
wildman10593
Honda CR-V & Element
Feb 14, 2013 06:34 AM
hondaciv5
Honda Civic (2001 - 2005)
12
Jul 31, 2007 08:55 AM
chrisw
Mar 26, 2004 08:07 AM
