Safe rev when cold
Old Nov 26, 2004 | 11:03 AM
the DA in HONDA's Avatar
Default Safe rev when cold
i know its getting to be around winter time and i was just kinda wondering what is a safe rev before the motor is fully warmed up. now its taking longer and longer before the motor warms up and i was just wondering what is the safest so i don't mess anything up.
Old Nov 26, 2004 | 12:20 PM
Slain's Avatar
as long as there is oil pressure you should be able to go just take it easy on it. i imagine 3k or so. just enough to get the car going with out stalling
Old Nov 26, 2004 | 12:29 PM
4U2NV's Avatar
Default Re: Safe rev when cold (the DA in HONDA)
I don't take mine anything above 3k till the temp gauge has been at normal operating temp for about 5 mins or so... You gotta think, if the temp needle just finally peaked, then the oil temp is prolly still pretty cool, considering coolant warms faster than oil...
Old Nov 26, 2004 | 12:39 PM
Gerbilo's Avatar
Default Re: Safe rev when cold (4U2NV)
I'm normally a real baby about this. I like to have the car sit on for a few minutes before I even move it outta my driveway after a cold night or anything.
Old Nov 26, 2004 | 12:44 PM
G-bonic's Avatar
Hijacked
Default Re: Safe rev when cold (Gerbilo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">I'm normally a real baby about this. I like to have the car sit on for a few minutes before I even move it outta my driveway after a cold night or anything.</TD></TR></TABLE>
Same here, i dont drive it til the temp needle pass the line or til the idle goes down to 750 - 800rpm
Old Nov 26, 2004 | 02:10 PM
b18vtek's Avatar
Up to 21/2 rpms should be good, that how I drive my car when it's cold. Haven't had any problems.
Old Nov 26, 2004 | 05:23 PM
qcktegls's Avatar
Default Re: Safe rev when cold (b18vtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">I don't take mine anything above 3k till the temp gauge has been at normal operating temp for about 5 mins or so... You gotta think, if the temp needle just finally peaked, then the oil temp is prolly still pretty cool, considering coolant warms faster than oil... </TD></TR></TABLE>
exactly right. ur coolant temp is warmed to normal but yet your oil is still cold. i stay below 3 grand every time unless ive been runnin my car for a while. i live in williamsport, pa so its gettin cold and all i do is drive to school and work. just to be safe and take car of your car dont push it above 3 or 4 unless ur running it more than 10 min.
Old Nov 26, 2004 | 06:11 PM
integraXTC's Avatar
3k.
Old Nov 26, 2004 | 06:26 PM
crawdad689's Avatar
Default Re: (chitwn91rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitwn91rs &raquo;</TD></TR><TR><TD CLASS="quote">3k.</TD></TR></TABLE>
Old Nov 26, 2004 | 08:20 PM
a1320addict's Avatar
word....when i get up at 7 to pick up my girl and dont have time to sit and pick my nose and wait for my motor to warm up..i drive and shift through every gear at 2500k....after about 5 minutes i start taking it a little higher....i mean be careful...but also think these motors are very durable...they can take a *light* beating
Old Nov 26, 2004 | 08:43 PM
92whtgsr's Avatar
Default Re: Safe rev when cold (yehiknowrite)
yah when i would wake up for school at 7 i would shift at 3000rpm untill needle moved past c
Old Nov 26, 2004 | 10:57 PM
TURBL0W's Avatar
what can happen if you don't warm up the motor?
Old Nov 27, 2004 | 01:23 AM
Sack Master's Avatar
Default Re: (lsvtec_power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec_power &raquo;</TD></TR><TR><TD CLASS="quote">what can happen if you don't warm up the motor?</TD></TR></TABLE>
Start your car up after its been sitting over night and free rev it to 8k until its warm. Let us know what you find out.
On a serious note. Unnecessary wear and tear on your bearings, rings, valve train, well let's just say every moving part inside the motor.
Old Nov 27, 2004 | 07:45 AM
JustinG60's Avatar
Default Re: Safe rev when cold (qcktegls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qcktegls &raquo;</TD></TR><TR><TD CLASS="quote">
i live in williamsport, pa </TD></TR></TABLE>
not all that far from my neck of the woods...
but if you actually like your car don't drive it till it warms up then you don't have to worry about it...
Old Nov 27, 2004 | 08:26 AM
russianroulette's Avatar
keep it under 3K RPM untill it warms up.
Old Nov 27, 2004 | 08:30 AM
NightCrawlerGsR's Avatar
Default Re: Safe rev when cold (toymx6)
Letting your car sit to warm up causes carbon buildup. Just drive it. That's what its made to do. If you can't drive your car when its cold and you're worried about breaking something in the process, then you've got problems. Just keep it around 3000rpm until the temp needle gets into the normal range.
Old Nov 27, 2004 | 09:37 AM
Chris_Bye's Avatar
wow and i thought i was a baby about it
i keep mine under or at 3k when i first start it up
Old Nov 27, 2004 | 12:22 PM
ProjectDarkBlack's Avatar
the manual says 1 minute for warm up, i would do at least one minute always, but take it easy with the revs, as well as throttle, more load means more blowby and the rings and the pistons and rings arent filling in all the gaps until it is warmed up
Old Nov 27, 2004 | 12:39 PM
95BlkGSR's Avatar
Default Re: Safe rev when cold (Stock_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS &raquo;</TD></TR><TR><TD CLASS="quote">
Same here, i dont drive it til the temp needle pass the line or til the idle goes down to 750 - 800rpm </TD></TR></TABLE>
same
Old Nov 27, 2004 | 01:15 PM
Skittles's Avatar
Same here. I also let it sit for 2-3 minutes running.
Old Nov 29, 2004 | 05:48 PM
Shinbo's Avatar
Default Re: (Skittles)
how about temperatures in the 20's? i just start it, wait for about 3-5 minutes, and then drive off. i shift as it's just about to hit 3000rpm. am i doing stuff right? or should i change my habits?
Old Nov 29, 2004 | 06:28 PM
G-bonic's Avatar
Hijacked
Default Re: (Shinbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shinbo &raquo;</TD></TR><TR><TD CLASS="quote">how about temperatures in the 20's? i just start it, wait for about 3-5 minutes, and then drive off. i shift as it's just about to hit 3000rpm. am i doing stuff right? or should i change my habits?</TD></TR></TABLE>
to me i dont think theres sumthins wrong wutcha been doin so i guess ur good..
Old Nov 29, 2004 | 06:37 PM
Honduh Chicken's Avatar
I fry gay turkeys
cluck that.. in wisconsin it get's really cold in winter.. I start up my civic and drop the hammer.. I would never do that in a car that I cared about, but I pretty much start it up and drive away, redline shifting... it get's warm real quick then..
Old Nov 29, 2004 | 07:20 PM
95BlkGSR's Avatar
Default Re: Safe rev when cold (Honduh Chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honduh Chicken &raquo;</TD></TR><TR><TD CLASS="quote">cluck that.. in wisconsin it get's really cold in winter.. I start up my civic and drop the hammer.. I would never do that in a car that I cared about, but I pretty much start it up and drive away, redline shifting... it get's warm real quick then..</TD></TR></TABLE>
lol...only it something breaks
Old Nov 29, 2004 | 08:37 PM
gearheadgirlie's Avatar
Default Re: Safe rev when cold (95BlkGSR)
I don't take it above 3k when shes cold for 2 reasons.
1)to be easy on her
and
2)so that tanabe dont 'talk that raaaassspy ****'.
