S3 Light blinking, code 9
Old Apr 20, 2011 | 04:49 PM
rlacsamana1989's Avatar
Default S3 Light blinking, code 9
Check under driver side at the TCM and blinks 9 times fast.
according to this
http://www.2ndgen.info/DIY/integra/atcodes.html
the code 9 has something to do with the a/t speed pulser???
is that the VSS? and where do I locate this part on a 1991 acura integra automatic.
Old Apr 20, 2011 | 05:37 PM
fcm's Avatar
fcm
Old Fart
Default Re: S3 Light blinking, code 9
I believe the VSS is in the cluster, the speed pulser I believe is the cable "drive" on the top of transmission close to the starter motor but closer to the firewall, just fallow the speedo cable to it, someone will have to correct me if I'm wrong.
Does the speedometer work? 94
Old Apr 20, 2011 | 05:44 PM
speedometer works just fine. just the light blinking.
Old Apr 20, 2011 | 07:00 PM
so am I looking at replacing the cable or is it more in depth?
Old Apr 21, 2011 | 06:39 AM
fcm's Avatar
fcm
Old Fart
If speedo works, cable is fine.
A correction, the speed pulser is located on the transaxel just below the master brake cylinder.
To test it you will need a multimeter, [set to continuity or lowest ohms settng], jack the front of car off the ground, connect meter to the 2 leads in the plug and spin the front tires, meter should show continuity and no continuity as tire rotates. 94
Old Apr 21, 2011 | 03:23 PM
okay thanks will give it ago in the morning when I get off work. If the test are fine what should I do next?
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
HT Chaplain
Oct 25, 2006 08:26 PM
Narcotic_y2k
Aug 28, 2005 02:31 PM
Joebroni
May 29, 2005 12:43 PM
civicdragger818
Nov 8, 2002 07:02 AM
