RSX deck into dc2?
Old May 7, 2003 | 11:09 AM
MaNyFacEs's Avatar
Default RSX deck into dc2?
Has anyone done this i know some mods need to be done to the face but will it wire up?
Old May 7, 2003 | 11:52 AM
WiggiE's Avatar
New User
Default Re: RSX deck into dc2? (MaNyFacEs)
When you say deck do you mean CD Player?
Old May 7, 2003 | 12:23 PM
MaNyFacEs's Avatar
ya it is the tape & cd (6 disc)
Old May 7, 2003 | 12:48 PM
integraL's Avatar
Default Re: (MaNyFacEs)
isn't the rsx stereo bigger than the panel for the integra? i'm sure the acura dealer can figure something out, though.
Old May 7, 2003 | 01:06 PM
MaNyFacEs's Avatar
ya it is bigger and i will have to modify a bit......but the wiring may be some thing else but i am unsure yet and i was looking to see if anyone else has done it before...thanks for the feed back
Old May 7, 2003 | 02:10 PM
WiggiE's Avatar
New User
Honestly, this should be moved to the Audio forum.
I believe they use similar wiring harnesses. You should be able to wire it up no problems. The biggest problem I would worry about is how are you going to mount it.
Old May 7, 2003 | 02:12 PM
integobsession's Avatar
There should be a way to install a cd player into your car... All the aftermarket cd players are all different sizes and ****... there's aren't any mades for a particular model of automobile. Just take it to a stereo shop and ask how much install will be...
Old May 7, 2003 | 02:16 PM
WiggiE's Avatar
New User
Default Re: (integobsession)
IMO, the time and effort to install this radio into your dash will be more than the cost of a nice aftermarket cd play. If you want both tape and cd, there are other options than just the RSX head unit.
Old May 7, 2003 | 04:35 PM
Default Re: (WiggiE)
If he already has one... then it'd be the same cost to install an aftermarket head unit.
Old May 7, 2003 | 05:21 PM
Commodore's Avatar
anyone know what the wattage on the RSX deck is and what the wattage on a Integra cd deck is? I would have to guess that the integra deck is 12watts or so, its pretty weak. Hopefully the RSX deck isnt like that at all.
Old May 7, 2003 | 05:25 PM
MaNyFacEs's Avatar
it's the bose 6 disc with a tape deck i hope it sounds good....my old stereo got jacked so i want a factory deck....so i got the rsx...i hope it sounds good
Old May 7, 2003 | 08:51 PM
WiggiE's Avatar
New User
If it's Bose it might be running different level resistance. Bose systems, if I remember right, run 8 ohms and other systems run 4 or 2 ohms.
Old May 7, 2003 | 10:56 PM
akhom's Avatar
To have it run you need BOSE Amp and Bose speakers. They are low Ohm rating like 1 or 2 ohm. The sound on Standard 4ohm speakers really low and powerless. You also need and harness plug for the amp and deck. The rest is easy wiring with your helms manual for RSx-S and your integra.
Old May 8, 2003 | 12:10 AM
WiggiE's Avatar
New User
Default Re: (akhom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akhom &raquo;</TD></TR><TR><TD CLASS="quote">To have it run you need BOSE Amp and Bose speakers. They are low Ohm rating like 1 or 2 ohm. The sound on Standard 4ohm speakers really low and powerless. You also need and harness plug for the amp and deck. The rest is easy wiring with your helms manual for RSx-S and your integra.</TD></TR></TABLE>
I knew the ohm load was different, but I couldn't remember which way it went.
SIRIUS VTEC
Sep 3, 2011 04:36 PM
AGR_Newark
Jan 31, 2008 08:03 AM
FakeJDMEF8
Apr 1, 2006 07:36 AM
RSXnotS
Feb 13, 2005 10:12 AM
Halo
May 24, 2004 11:51 PM
