is RS and LS interchangable?
Old Jul 9, 2004 | 09:41 PM
Accord2NR's Avatar
Default is RS and LS interchangable?
lets say if i have an rs and i get lets just say.....intake for an ls, will it fit on a rs, both 2 door, both 5 speed manual, i mean they are both the same one without sunroof, right? thanks i was curious plus this might help others later.
Old Jul 9, 2004 | 09:53 PM
Hypa-R Integ's Avatar
Default Re: is RS and LS interchangable? (AcuraINTEGRAGSR)
yes they are same car, ls has more options. same motor and all though
Old Jul 9, 2004 | 10:02 PM
patmcd's Avatar
Default Re: is RS and LS interchangable? (Hypa-R Integ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hypa-R Integ &raquo;</TD></TR><TR><TD CLASS="quote">yes they are same car, ls has more options. same motor and all though</TD></TR></TABLE>
That is correct. The only differences btwn the LS and RS are cosmetic. Motor/drive train/etc are all the same.
Old Jul 9, 2004 | 10:07 PM
Accord2NR's Avatar
so wut about if a swap in a gsr motor in a ls or rs car. lets say if i wanted exhaust, would i buy exhaust for gsr or ls/rs after the swap. thanks
Old Jul 10, 2004 | 01:04 AM
MajorPayne's Avatar
they should be very similar as long as they are for the correct year, however im not too sure on how different the length is on the headers of the two, so there might need to be some cutting and welding done, but if you put a gsr engine in say a 95 ls, then just go with the 95 gsr exhaust or any 3rd gen gsr exhaust for that matter they are the same as far as i know, but im assuming youre talking about a 3rd gen integra to begin with, if you put the gsr engine in a 2nd gen integra, then get the 92-93 gsr exhaust so they should match up
Old Jul 10, 2004 | 01:18 AM
tC_Dragon's Avatar
Default Re: is RS and LS interchangable? (MajorPayne)
Let me first say that i will comment under the assumption that you are referring strictly to the 3rd gen teg.
Ok..
1. RS and LS do share the same motor/tranny and are very similar. And as already mentioned the LS has some more options unavailable to the RS like the sunroof. The RS comes standard with manual door locks. And was not equipped with a sunroof from factory. But the big one you missed was the fact that RS did no have ABS while the LS comes standard with ABS.
2.The hangers for either a gsr or ls exhaust are all in place i believe under the chassis of the car. So you can run either exhausts systems on the car. But you would probably need to choose either the RS/LS or GSR apps. and stick with it for Header, cat and exhaust because i believe the lenghts differ. However i vaguely recall someone stating that the exhuast ports on the head of all b18 motors is exactly the same so the flanges for any of the corresponding headers would mate up against it, but i cannot confirm that the hieght of all motors would clear.
Old Jul 10, 2004 | 07:35 AM
FunkDaddyFresh's Avatar
Default Re: is RS and LS interchangable? (pdcdragon)
the rs is lighter
Old Jul 10, 2004 | 11:23 AM
R4ND0M's Avatar
Default Re: is RS and LS interchangable? (FunkDaddyFresh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunkDaddyFresh &raquo;</TD></TR><TR><TD CLASS="quote">the rs is lighter</TD></TR></TABLE>
Cuz it doesn't have the cosmetic stuff!!
Old Jul 10, 2004 | 11:27 AM
DriveSideWays's Avatar
yes RS lacks sunroof the only thing i like about an LS
Old Jul 10, 2004 | 11:35 PM
Accord2NR's Avatar
bump! so every or most ls aftermarket parts can be instlaled into an RS?
Old Jul 10, 2004 | 11:43 PM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraINTEGRAGSR &raquo;</TD></TR><TR><TD CLASS="quote">bump! so every or most ls aftermarket parts can be instlaled into an RS?</TD></TR></TABLE>
yes... i have yet to see an aftermarket part that will fit one but not another.
97RSTEG
Jul 6, 2006 04:19 PM
Rustang Cobra
Feb 22, 2006 03:24 PM
sickstyle83
Feb 9, 2004 12:12 PM
im a fob
Jan 25, 2004 05:00 PM
