RS door panels.
Old Feb 15, 2003 | 02:29 PM
GSblueRacing's Avatar
Default RS door panels.
I got this yesterday.
If I put these on my integra, because I got to disconnected the automatic door lock, Will it interfere with the alarm system? or cause problem with closing the door or locking the door?
Old Feb 15, 2003 | 03:28 PM
shockwave's Avatar
Default Re: RS door panels. (GSblueRacing)
I don't think it will interfere with your alarm keyless enrty. I put another set of door panels in my 91 teg and they didn't have the hole for the power doorlock switch. So I just left the switch out and my keyless entry still works with my alarm. It should be the same with the 94+ tegs too. You will just have to reach over and unlock the passenger side door manually now if you are inside.
HTH
Kev
Old Feb 15, 2003 | 04:32 PM
ITR#132's Avatar
Your alarm will have no problems.
Old Feb 15, 2003 | 04:35 PM
Understeer's Avatar
How much did those cost each?
Old Feb 15, 2003 | 05:04 PM
Default Re: RS door panels. (Understeer)
$5 each.
Old Feb 15, 2003 | 06:04 PM
MugenGTR's Avatar
only $5? not bad, i have mines disabled and no, it doesn't messes up ur alarm keyless entry, i think i'm gonna get these bazel tomorrow,
Old Feb 15, 2003 | 07:33 PM
B U N M A N G O's Avatar
Default Re: RS door panels. (MugenGTR)
might be a retarded question, but what's the diff btwn these and ls/gs/gsr/type-r door panels? just the power door lock hole is filled in? and why do people want these just to look cleaner inside? just wondering, that's all... please excuse my ignorance
Old Feb 15, 2003 | 07:35 PM
Understeer's Avatar
Default Re: RS door panels. (bunmango)
To reduce the ease of theft because the power door lock switch is quite visable and is a means to open the door/steal the vehicle with a slim jim..
It has nothing to do with appearance. Only to reduce ease of theft.
Old Feb 15, 2003 | 07:46 PM
wow good idea... didn't think of that. It's sad but true, it's really easy to unlock the doors on an Integra, especially sedans because the windows are frameless. On the brighter side, it's easy to unlock if you accidentally lock yourself out of your car thanks for the info
Old Feb 15, 2003 | 10:18 PM
ingrate's Avatar
25 Year Member
All you have to do is unplug the switch, but most people aren't comfortable with the fact that there's a shiny non functional switch just sitting there
Old Feb 15, 2003 | 11:01 PM
tC_Dragon's Avatar
Default Re: RS door panels. (ingrate)
Only thing about this mod is that i like having pwrdoorlocks especially when i'm tryin to lock or unlock with a passenger sittin next to me.. its kinda rude to lean over the person ya kno? depending on who they might be... but ...
i've always wanted to relocate the switch to where teh ebrake handle is.. even did a little research for it.. and found that the sl500 benz one actually looks like it'll fit perfectly, but i never got around to ordering the part and doin it... too lazy.
Old Feb 16, 2003 | 10:32 AM
Default Re: RS door panels. (pdcdragon)
good idea... I might look into doing something like that
Old Feb 16, 2003 | 12:18 PM
zilverz's Avatar
True.. disconnecting those power doorlocks will greatly reduce the chance of theft
Old Feb 16, 2003 | 01:56 PM
Rtzx9r's Avatar
GDD 1%
Default Re: RS door panels. (zilverz)
my only complaint is that my alarm locks the doors when you start the car- and I have no way to unlock the hatch unless I shut off the car.
Dang thieves.
at least they can't get the car that way, but there are other ways.
Old Feb 17, 2003 | 01:04 AM
tC_Dragon's Avatar
Default Re: RS door panels. (Rtzx9r)
Dang thieves.
This gives you reason to relocate the switch, after you replace the bezel wit the rs one.
Old Feb 17, 2003 | 06:51 AM
zilverz's Avatar
Dang thieves.
What are you talking about ? My latch is still there .. you just manually push it ... Even with the RS handles.. you still have your latch to manually unlock it ..
Old Feb 17, 2003 | 10:55 PM
95gsr's Avatar
Dang thieves.
mine does the same i also have my lock disabled and if you start the car with the drivers door open the doors do not lock
Old Feb 18, 2003 | 10:13 AM
Rtzx9r's Avatar
GDD 1%
Have you ever dealt with routing wires through the bulkhead in the door jam? It's not worth the hassle.
Where can you get those bezels for 5 bucks each?
Old Feb 18, 2003 | 10:24 AM
tC_Dragon's Avatar
i believe you can actually reach the wires in teh kick panel if you plan on rerouting... you can leave the original wire harness for the switch where it is in the door.
condor22
Jan 23, 2019 09:16 AM
John Wilson
Audio / Security / Video
Sep 2, 2013 09:58 PM
PatrickGSR94
Feb 6, 2009 08:51 AM
Stealthycivicsi
Feb 19, 2008 02:48 PM
dut
Jun 30, 2003 06:35 PM
