RPM problems
Old Mar 29, 2004 | 11:21 AM
lastpunkinline's Avatar
Default bogging at 7.2 RPM's
It just happened today but, i was starting to get on it and I was in 1st, but when i was at about 7.2 RPM's it sounds like its at 8.5 and i start slowing down. I dunno if it has anything to do with it, but last night i started hearing this noise, as if something was loose, my friend sounds like my exhaust is loose, but my dad said it might be my tranny, but i dunno about either of those. Help please!
Modified by lastpunkinline at 10:09 PM 3/29/2004
Old Mar 29, 2004 | 01:00 PM
Default Re: RPM problems (lastpunkinline)
bump
Old Mar 29, 2004 | 01:09 PM
Default Re: bogging at 7.2 RPM's (lastpunkinline)
bump
Old Mar 29, 2004 | 01:10 PM
nolexforever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">i was starting to get on it and I was in 1st, but when i was at about 7.2 RPM's it sounds like its at 8.5 and i start slowing down.</TD></TR></TABLE>
could you elaborate on that??
are u saying, at 7200 rpm's your engine "sound" changed to sound like it was at 8100 rpms?
did you warm the engine up a bit before hitting VTEC?
Old Mar 29, 2004 | 01:11 PM
Default Re: RPM problems (nolex7)
no when it hits 7.2 it starts bogging and slows down, as if i were to redline it to the max at 8.5, and i don't have Vtec i have an integra
Old Mar 29, 2004 | 01:20 PM
tdotteg's Avatar
"no when it hits 7.2 it starts bogging and slows down, as if i were to redline it to the max at 8.5, and i don't have Vtec i have an integra"
LMFAO
P.S. buddy, i was forced to sign up just to respond to your post!
Old Mar 29, 2004 | 01:26 PM
ITR21's Avatar
Default Re: RPM problems (tdotteg)
hahaha for the love of god and the life of your car. Do not try to fix this yourself. Take it to the dealer.
Old Mar 29, 2004 | 01:27 PM
xplanetearth420x's Avatar
i dont have vtec i have a integra!
first of all are you STUPID?lets see last time i cheacks gsr's and type r's are vtec they are integra's
Old Mar 29, 2004 | 01:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">no when it hits 7.2 it starts bogging and slows down, as if i were to redline it to the max at 8.5, and i don't have Vtec i have an integra</TD></TR></TABLE>
my bad, didnt notice you had a non-VTEC integra.
what you are describing is the rev limiter..non-VTEC integras redline at approx. 6800 rpm's..you cannot rev higher than that under normal conditions..the ECU will not let you do so hence you are suppose to shift to the next gear.
Modified by nolex7 at 9:44 AM 3/30/2004
Old Mar 29, 2004 | 01:37 PM
oh so then theres no problem?Its natural?
Old Mar 29, 2004 | 01:39 PM
moron, i meant i have a non-vtec integra, if u were smart you'd look at my profile
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">oh so then theres no problem?Its natural?</TD></TR></TABLE>
yes, that is normal.
Old Mar 29, 2004 | 01:49 PM
Is there governers on integras?
Old Mar 29, 2004 | 03:58 PM
tdotteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">moron, i meant i have a non-vtec integra, if u were smart you'd look at my profile</TD></TR></TABLE>
You're the moron for reving your non vtec motor to 7.2
Old Mar 30, 2004 | 07:24 PM
iskendi's Avatar
Default 92 integra gsr rpm runnig high
Hey,
I have an 92 Acura Integra GSR and it seems like the rpm's run high. For example when I'm driving on the highway doing 60mph the rpm is exactly 3500rpm it seems very high to me it should be a little below 3000rpm. I just had the clutch recently replaced. If someone could give me some help and tell me if this is normal or not.
Old Mar 30, 2004 | 08:21 PM
sPaRk'iT's Avatar
WTF?? if your car doesnt have vtec, then its not suppose to go up that high with stock internals, non-vtec integra stock redline at 6.9rpm, and please dont try to go over that if your car is not built.
Old Mar 30, 2004 | 08:38 PM
Quiks66's Avatar
Default Re: RPM problems (sPaRk'iT)
LastPunkInline: do yourself and your motor a favor: Look at your stock tachometer (which shows how many rpm's your motor is revving to) and read the numbers all the way up to 6800. You'll see that after that point the white numbers turn into RED NUMBERS. This is the designated Redline of your motor. Attempting to revv past this so called Redline will eventually cause your ECU (car's computer) to cutoff fuel and limit your revving madness. Do not revv up to or past this point ever again unless you are driving a car with a higher revv limit or you have swapped in a different or built motor. Doing so will result in extensive wear and possible damage to your motor, resulting in additional maintenence and repairs on your part. Drive safely.
Old Mar 31, 2004 | 12:59 AM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdotteg &raquo;</TD></TR><TR><TD CLASS="quote">LMFAO
P.S. buddy, i was forced to sign up just to respond to your post!</TD></TR></TABLE>
damn owned....
maybe your redline is 6800? or something?
CodyC142
12
Jul 29, 2008 02:19 PM
fedcep
May 3, 2005 09:09 AM
eyespy
Jun 10, 2004 12:39 PM
216.226.142.95:27016
Sep 23, 2003 08:05 PM
Miz101
Sep 16, 2003 09:41 AM
