rpm problems
Old Sep 10, 2006 | 12:08 PM
wesgsr's Avatar
Default rpm problems
my 99 gsr has all the crap msd, 18g turbo, gears, uberdata, rtp kit, 450cc dsm injectors, any way the rpms bounce at 3250 like a rev limiter but the uberdata has all the stuff set correctly but this rpm issue is driving me mad. any help is great
Old Sep 10, 2006 | 01:06 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: rpm problems (wesgsr)
Any codes being thrown? Check the ignitor and make sure it's grounded. I had the same problem for a while on my car and my friend's.
Anyway, what are "gears"? Did you modify your gearing/final drive? Just wondering because the GSR gearing is one of the most efficient for overall acceleration and gas mileage.
Old Sep 11, 2006 | 07:53 AM
wesgsr's Avatar
Default Re: rpm problems (shamoo)
igniter do you mean coil or what
Old Sep 11, 2006 | 07:56 AM
wesgsr's Avatar
yes there are codes but the car has been converted to obd1 and i have yet to figure out how to get the codes out, the gears are cam gears
Old Sep 11, 2006 | 11:12 AM
a_98_dc4's Avatar
there is a little plug that you have to jump the two wires and the code will flash on the cel. the plug is located on the passenger side of the dash near the kick panel on most conversions...
Old Sep 14, 2006 | 05:08 AM
thaipham806's Avatar
Default Re: (a_98_dc4)
iacv?
Old Sep 14, 2006 | 06:12 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: (thaipham806)
I was thinking the IACV, it's free to adjust. So you may want to start there. Then start to check for CEL.
Old Sep 15, 2006 | 07:55 AM
wesgsr's Avatar
tried the plug and the cel just stayed on no blinking
Old Sep 15, 2006 | 07:56 AM
wesgsr's Avatar
Default Re: (wesgsr)
how do you adjust the iacv , i have also checked the ignitor and it still did the rpm bounce thing
Old Sep 15, 2006 | 11:51 AM
JasonST's Avatar
Are u saying that this happens at idle? Or does it happen when ur driving and u just can't rev past 3250 rpms? Also u should jump ur service connector to find out what codes ur getting.
Old Sep 17, 2006 | 10:22 AM
wesgsr's Avatar
Default Re: (JasonST)
it wont rev past 3200, jumping the plug does nothing the cel just stays on
Old Sep 23, 2006 | 06:08 AM
wesgsr's Avatar
found the prob the ecm was bad put a new one in and ran great time for the tune w/ wide band
kaddi88
19
Aug 31, 2008 06:24 PM
Mr. Anderson
Aug 25, 2008 07:42 PM
Si_chRis
85
May 19, 2008 04:07 PM
EH3Civic
Aug 9, 2005 09:16 AM
Mr. Anderson
Mar 29, 2004 05:46 AM
