rough idle, please help
Old Dec 13, 2009 | 08:22 PM
jlfrnce's Avatar
Default rough idle, please help
ok i have been over this whole car, gonna try cap, rotor, wires tomarrow, but i have a rough idle, sounds like a miss but vac/boost gauge is at 15, normally was at 25 vac side, let me tell ya what i did and have, 94 ls with gsr swap and JRSC, i got a rod nock so i replaced everything, crank pistons and rods, bearings seals rings head was redone too, so whole new motor, well i also up'd the boost to my max i can go and trying to break the motor in, i melted pistons, rings, both main and rod bearings and once again had to get new, even new head gasket, well when i fire it back up i got my rough idle problem and have sprayed carb cleaner everywhere and cant find a leak! do you guys have any idea's of what to look at next?i dont think it could be cap, rotor, wires but gonna end up getting new 1s just incase. like i said it seems like maybe a miss but vac gauge is low
Old Dec 13, 2009 | 08:50 PM
abyssinian's Avatar
Default Re: rough idle, please help
wow
Old Dec 14, 2009 | 09:38 AM
jlfrnce's Avatar
tried new cap, rotor, wires and still same issue!
Old Dec 14, 2009 | 09:59 AM
iH8RICERZ's Avatar
have you tried retuning your set up yet?
Old Dec 14, 2009 | 10:12 AM
Bsharpe's Avatar
I think its your ivac b.c. mine is doing the same thing kinda....
Old Dec 14, 2009 | 10:22 AM
SisterFister's Avatar
try to clean your iacv, i had a weird idle, that went up and down until warmed, i cleaned it, and it worked
Old Dec 14, 2009 | 01:55 PM
jlfrnce's Avatar
its not that up down its a miss, and tuning place said to put 1000 miles on motor, but i had just burned pistons/rings and all bearings up, at 121 miles with a base tune. i had it running when had 10#boost, beat the snot out of it for 11months and gave it a rod knock so rebuilt all new and up'd to 14# boost and been having problems, I just pulled #1 cylinder plug wire off and motot\r didnt die down well i did them all but #1 didnt di down, my dad said plug wasnt firing and #2 doesnt look like doing to much better tho, but swapped plugs and still number 1 wont die down when pull plugwire
Old Dec 14, 2009 | 06:30 PM
jlfrnce's Avatar
swapped out plugs for old 1s and still same issue, i got 180 compression all way across, I chaecked and got spark, its orange, my dad says should be white
Old Dec 14, 2009 | 06:33 PM
Matt55's Avatar
checked the dizzy?
Old Dec 14, 2009 | 07:25 PM
Bsharpe's Avatar
I would check the dizzy that's prob your problem and I would get a exturnal coil
Old Dec 14, 2009 | 07:33 PM
jlfrnce's Avatar
how do you check the dizzy?
Old Dec 14, 2009 | 07:39 PM
Matt55's Avatar
swap wires with a cylinder that you know is working
Old Dec 14, 2009 | 07:42 PM
Bsharpe's Avatar
I'm not to sure I know when you got a weak spark like that I would see if your friends or if you could by one for cheap its worth having a good one laying around
Old Dec 14, 2009 | 08:02 PM
jlfrnce's Avatar
it wont even change when i move the dizzy either, how it runs.
Old Dec 15, 2009 | 05:56 PM
jlfrnce's Avatar
What is this sensor insideon the right of the distributor? ------
Old Dec 17, 2009 | 12:13 PM
jlfrnce's Avatar
well i tried a new distributor and still same issue, any1 else with any idea's?
Old Dec 17, 2009 | 12:17 PM
Matt55's Avatar
checked your exhaust valves? low vacuum + misfire could cause that
Old Dec 17, 2009 | 12:27 PM
jlfrnce's Avatar
how you do that?
Old Dec 17, 2009 | 12:35 PM
Matt55's Avatar
Have you already done a compression test? but idk how conclusive that would be ultimately just take off the head and see if the exhaust valves are burnt
Old Dec 17, 2009 | 12:43 PM
jlfrnce's Avatar
compression was 180 across
Old Dec 17, 2009 | 12:48 PM
Matt55's Avatar
How is your afr, sounds like you could have a lean misfire at idle
Old Dec 17, 2009 | 01:34 PM
jlfrnce's Avatar
damn now it wont even start, with either dizzy in car, wtf? but when it was and after i drove around for lil bit the a/f guage(dummy) would go to lean side, so babied it alot to get home safe
Old Dec 17, 2009 | 01:57 PM
Matt55's Avatar
AHH! its prolly causing a lean misfire which is giving you the rough idle
Old Dec 17, 2009 | 01:59 PM
Matt55's Avatar
you checked the plugs? and injectors?
Old Dec 17, 2009 | 02:51 PM
jlfrnce's Avatar
plugs are brand new, and dont have this ohm tester to test Injectors, know of another way? now i runs, had a ground wire break off, but now also get a ecu code 22, so will clean out the vtec when i have daylight! when i drive around after it gets warmed up, it shows on the a/f gauge it is lean
