Rotors
Old Dec 9, 2008 | 02:43 AM
TigerLy's Avatar
Icon2 Rotors
I was changing my brakes and rotors and i was using an impact driver to take off the 2 screws holding on the rotors but bit broke off in one of the screws and i couldn't pick it out to put in a new bit so i just decided to drill it out since those screws are pointless anyways.. but none of my drill bits would cut threw that broken bit.. it would cut through the head of the screw but it won't even scratch that broken bit.. anybody have any ideas of how to take that out?
Old Dec 9, 2008 | 04:08 AM
weavertime1's Avatar
Torch it...BTW those screws aren't really necessary in holding on the rotor, as the lug nuts actually do that. Good luck!
Old Dec 9, 2008 | 06:36 AM
90_EX_Civic's Avatar
actually, they "hold" the rotor, but are not necessary. you should be good with out the screws.
Old Dec 9, 2008 | 08:49 AM
I meant they don't actually hold the rotor meaning that without them the rotor won't fall off or anything...
Old Dec 9, 2008 | 11:43 AM
slaminsam's Avatar
Yeah you are more than likely going to have to melt it out. You could try shattering it out with a punch and a hammer. It works every once and a while.
Old Dec 9, 2008 | 01:23 PM
TigerLy's Avatar
yeah i know you that does screws aren't needed.. and i was going to torch it out but i was just wondering if anybody had any other ideas.. well thanks guys i will try that.. if anybody has any other insights on how to get it off please don't hesitate to offer ideas..
Old Dec 9, 2008 | 01:35 PM
Dogginator's Avatar
Daisy... Daisy...
A torch may thermally shock it to release the broken bit. Otherwise, use a chisel to sever the head off of the screw. If you have a cutting torch, you can heat the screw head and burn it off.
Old Dec 9, 2008 | 01:45 PM
thewrai6th's Avatar
When I broke off the impact driver tip in a rotor screw, I took out the Rotozip and cut a nice large flathead slot. It was enough to break it loose.
Otherwise, get a better drill bit or drill and go to work. If you don't want the rotor, get out the grinder
eric416
Dec 2, 2009 02:55 PM
zero708970
Nov 10, 2008 07:33 PM
Wendys or Bust
Oct 24, 2006 07:11 PM
OVRsi
May 29, 2003 11:39 PM
SIMATIC
May 17, 2003 09:54 PM
