Rotors
Go over to the sponsor classafied area, there is a guy called stop check(maybe check stop) He has brembo rotors and brembo blanks, check him out. I am jsut about to order some rotors and lines from him, he has been super cool to work with
Get some Autozone Blanks. They're pretty cheap at $21/rotor and they're decent quality. I have no complaints with them and they even come with a 90 day warranty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote">Get some Autozone Blanks. They're pretty cheap at $21/rotor and they're decent quality. I have no complaints with them and they even come with a 90 day warranty.</TD></TR></TABLE>
I third this idea. They have 90 day warranty on Valucraft ($14), and 2 year on Duralast ($22), both are very good. Usually the stores either don't stock as much or run out of the cheaper ones, but they always have the Duralast ones.
Just make sure you break-in your new pads and rotors, and they will do very well.
http://stoptech.com/whitepaper...h.htm
i've been using my autozone lowest model rotors all the way around on my LS for over 2 years and i've never had problems with warping, cracking, or anything. i've beaten on the brakes occasionally, no really big race courses or anything, but i use 'em really hard on the street all the time. integra brakes just feel so good . . . i can't help it! stopping is almost as much fun as going sometimes!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">I third this idea. They have 90 day warranty on Valucraft ($14), and 2 year on Duralast ($22), both are very good. Usually the stores either don't stock as much or run out of the cheaper ones, but they always have the Duralast ones.</TD></TR></TABLE>
as an autozone employee, i fourth this.
if you just want something to get you by, get the valucraft. if you want to spend 5-10 bucks more, you can get the duralast with a 2 year warranty.
Modified by LSvtec03 at 10:38 PM 1/31/2005
damn i thought brake rotors would be way more ... my drivers side front rotor snaped a couple of days ago in three parts
but if i can get them that cheaps its not a problem thank \you autozone
Yep...I was going to post this...ah hell: https://honda-tech.com/zerothread?id=831188
It's such a good deal. Brembo makes some of the best brakes in the world...you can't really go wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R »</TD></TR><TR><TD CLASS="quote">Yep...I was going to post this...ah hell: https://honda-tech.com/zerothread?id=831188
It's such a good deal. Brembo makes some of the best brakes in the world...you can't really go wrong. </TD></TR></TABLE>
Brembo does make some good rotors, but I'd still recommend Autozone rotors. I don't think that the Brembos would out perform the Autozone rotors. In the end, I think that good pads and brake fluid would have more of an effect on braking than the rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qcktegls »</TD></TR><TR><TD CLASS="quote">yeah if ur lookin for something cheap and that will last just go to autozone and get some rotors and put em on urself. dont go to a shop because they will rape you. </TD></TR></TABLE>
i have had mine for almost a year with no problems to speak of.
when i said i had used mine for 2 years w/ no problems, i meant i had been using the cheap ones with practically no warranty. they've been fine, and i'd have to imagine that the better ones are, well, better. but i don't care. next time they're due, i'm going for Axxis Ultimates and autozone cheapie rotors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96integraGSR »</TD></TR><TR><TD CLASS="quote">or just get them turned</TD></TR></TABLE>
how much are you going to pay to have them turned?
and shaving the rotors, only makes them more likely to warp
for another couple bucks just buy a new rotor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">
for another couple bucks just buy a new rotor</TD></TR></TABLE>
i agree.
i agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">from my experience, autocross has no adverse effect on rotor life
HPDE on the other hand, kills rotors fast</TD></TR></TABLE>
quit usin the brakes then.
problem solved.
Oh, and Autozone cheapos
problem solved.
yeah, autocross doesn't need big brakes. you don't go fast enough to get the rotors really hot, so bigger/denser rotors are is just a means to gain evil rotating mass.
and that's all the better rotors are is denser, so they hold more heat. also minor changes in alloy, but who's counting?
