Rotating..
Old Nov 26, 2001 | 03:45 PM
IntegraGSR23's Avatar
Default Rotating..
I am about to drop my car (1.25"), once that is done how often you think I should rotate my tires? I know that a camber kit is not required, due to the fact it is not exceeding 1.50", correct? I want to get the maximum life out of my tires. Thanks
Old Nov 26, 2001 | 03:56 PM
Calavera's Avatar
Default Re: Rotating.. (IntegraGSR23)
Recommended tire rotation is every 7500 miles... (according to the car manual I think)
Old Nov 26, 2001 | 04:25 PM
Default Re: Rotating.. (Calavera)
Even though it is dropped? 7500? I am guessing since it's dropped and there is some negative camber it should be done more often? Anyone else?
Old Nov 26, 2001 | 04:44 PM
integra7's Avatar
New User
with a drop of 1.25", your camber should be fine. just make sure you get an alignment. After that, make sure you check up on your tires. I have about 1.5-1.75" drop and my tires are in good condition, i rotate every 7500. but every car is different. if you do notice uneven tread after your lower it, look into investing in a camber kit.
Old Nov 26, 2001 | 06:53 PM
nfn15037's Avatar
Default Re: Rotating.. (integra7)
Damn, im lucky to get 7500 miles out of a set of fronts, LOL, j/k. I usually rotate every 4-5k, depending on how many track days i do.
Old Nov 26, 2001 | 06:55 PM
gsr camel's Avatar
I do it every 2 times I change my oil
twanks
Fo-Do Fanatic
Jan 2, 2010 04:26 AM
jnuanz382
May 4, 2007 10:11 PM
Tuesdaynightfever
31
May 24, 2006 06:03 AM
vsm dc4
Suspension & Brakes
13
Feb 7, 2005 04:37 AM
theguy003
Jan 25, 2002 05:08 PM
