Freshly replaced IACV gone bad again. What could be causing this?
Old 07-28-2011, 07:16 PM
BoldFart16's Avatar
Default Freshly replaced IACV gone bad again. What could be causing this?
My B18C didn't want to start and was bogging and all sorts of weird stuff and threw a code. Code 14. Bad IACV. I replaced it and bam everything was golden for about 100 miles or so, then out of nowhere the same exact symptoms. Threw a code 14. Square one again. I bought an OEM Nissin IACV mind you, I always buy Honda Genuine parts. I find it hard to believe that I got a faulty IACV from Honda, so I'm thinking that something might be causing my IACVs to go bad. Any ideas? Bad map on my chipped p28? Bad ECU all together maybe? Wire shorting out somewhere?
Old 07-28-2011, 07:49 PM
crazybeanery0's Avatar
Default Re: Freshly replaced IACV gone bad again. What could be causing this?
What intake manifold do you have (OEM, ITR, Skunk2, Blox, etc.)? Also, are you using a stock harness or have you modified it at all? Along with the new IACV, did you replace the o-ring gasket for it?
36455-PV0-000 - GASKET, ELECTRONIC AIR CONTROLVALVE (KEIHIN)
Old 07-28-2011, 09:14 PM
BoldFart16's Avatar
Yeah I replaced the gasket. Intake is a replica ITR for B18C, could be an old blox or skunk2 or something. I have an Apexi VAFC spliced into the harness.
Old 07-28-2011, 09:16 PM
mouab18c1's Avatar
You bought a Nissan IACV? To be honest your car will run better without the VAFC.
Old 07-28-2011, 09:25 PM
BoldFart16's Avatar
NISSIN.
And yes I know the VAFC is pointless. It's a remnant of a time when tuning wasn't as inexpensive and less widely available.
Old 07-28-2011, 11:32 PM
mouab18c1's Avatar
Get a probe light or a multimeter and check for voltage at your IACV.
Old 07-29-2011, 05:32 PM
BoldFart16's Avatar
Figured it out. Previous owner cut one of the wires to the IACV and repaired it. It just popped out of the sleeve. I didn't notice this before because the sleeve was covered in a ton of electrical tape. In doing this I must have screwed up my TPS sensor somehow, because now it's throwing code 7.
Old 07-29-2011, 08:32 PM
Good job man. Glad you figured it out. When I re-did my harness, I always soldered + heat shrank my wires if I had to cut them to lengthen/shorten them. This is preferred over crimping/doing whatever the last guy did
Beau Gotti
06-14-2010 01:05 PM
phoshyzzle
09-24-2008 08:06 PM
98TypeSH
11-15-2005 04:04 AM
intekragsr
05-22-2003 03:32 AM
Quick Reply: Freshly replaced IACV gone bad again. What could be causing this?
