Reverse lights stuck on
Old Aug 6, 2012 | 11:32 AM
92gsr-teg's Avatar
Icon2 Reverse lights stuck on
I have 92 gsr teg that the reverse lights and tail lights will not go off.
any advice?
Old Aug 6, 2012 | 04:39 PM
GodlikeGS-R's Avatar
Default Re: Reverse lights stuck on
I would unplug the reverse switch on the trans and see if the rev lights go out.
Old Aug 6, 2012 | 05:31 PM
92gsr-teg's Avatar
where is that switch located on the trans. top or bottom
im new to the import scene
Old Aug 6, 2012 | 05:35 PM
sirtef9's Avatar
front bottom of transmission if your looking at it from the front of the car.
Old Aug 6, 2012 | 05:43 PM
92gsr-teg's Avatar
thanks, ill look into that. maybe thats whats killin my battery
on a second note, every know and again it dosen't want to start when you push in the clutch to and turn the key nothing happens. you have to try multiple times
Old Aug 6, 2012 | 05:45 PM
sirtef9's Avatar
no turning over or anything?
Old Aug 6, 2012 | 05:47 PM
92gsr-teg's Avatar
nothing at all.
Old Aug 6, 2012 | 05:49 PM
sirtef9's Avatar
could be ignition switch going out or possible starter.
Old Aug 6, 2012 | 05:54 PM
92gsr-teg's Avatar
ill try looking into those things, ive got it tore apart at the moment.
thanks for the help.
do you know where to find a wiring diagram for this year car, it dosen't have p/s or a/c but has all the wiring, would like to wire tuck or get rid of what i dont need
Old Aug 6, 2012 | 05:58 PM
sirtef9's Avatar
http://www.hondata.com/techwiringgsr.html, ill look for more
Old Aug 6, 2012 | 06:01 PM
92gsr-teg's Avatar
thanks for the help
Old Aug 6, 2012 | 06:05 PM
sirtef9's Avatar
anytime buddy
Old Aug 6, 2012 | 06:08 PM
92gsr-teg's Avatar
where is a good place to get quality parts for this gen car? that aren't over priced
Old Aug 6, 2012 | 06:11 PM
wavieDC's Avatar
Change the switch make sure the wires have not been spliced and switched
Old Aug 6, 2012 | 06:13 PM
sirtef9's Avatar
oem parts stick with the dealership
Old Aug 6, 2012 | 06:14 PM
92gsr-teg's Avatar
thats another problem. this thing is a wiring nightmare. bought it wrecked and getting it back together from where they started.
Old Aug 6, 2012 | 06:15 PM
92gsr-teg's Avatar
what about aftermarket stuff?
JamesDMdb1
Oct 11, 2010 06:42 AM
ttk3
Lighting
Jan 14, 2008 04:34 AM
slickrc
Jul 28, 2007 02:55 PM
charlee
Apr 29, 2006 01:08 PM
estillme
Mar 12, 2004 11:08 AM
