resistor wiring problem
Old Jul 28, 2009 | 05:33 AM
matttegra's Avatar
Default resistor wiring problem
Hey guys, i'm swapping my injectors for DSm on my 99 GSR. First question, there's yellow/black wires on all 4 existing injector clips and on my new obd1 injector clip, except that on the obd1 ones, the yellow/black wire are inverted, should i connect the two yellow/black wires together or it doesn't matter?? Second question, when i checked for continuity in the unused plug, i get two pins per injectors and the same two pins for all 4 injectors, so should i connect two injector wire to one unused plug wire??? I 've read every post on how to do it and it always says that there is one wire per injector and not the same two for all. Help me please.
Matt
Jayman_Gsr
Nov 21, 2008 05:18 AM
Mr. Vapor
May 7, 2005 01:03 AM
Mr. Vapor
Apr 27, 2005 12:29 PM
Frozen E
Oct 28, 2004 08:51 AM
TurboB18C1
Apr 17, 2002 01:49 PM
