Resetting the ecu--is it necessary to do it manually or will it do itself?
Old May 14, 2005 | 09:02 PM
WTB AUTO EK's Avatar
Default Resetting the ecu--is it necessary to do it manually or will it do itself?
I just did some stuff to my car because of codes. I didnt reset the ecu, but I was curious if it was necessary. I ended up doing it, but hypothically, is it necessary?
will the car self adjust or do i have to do it manually?
Old May 14, 2005 | 09:56 PM
5 Speed AP2's Avatar
Default Re: Resetting the ecu--is it necessary to do it manually or will it do itself? (SSImpala)
If you reset your ecu already, it will take care of the rest next time you start it up.
Old May 15, 2005 | 01:45 AM
yrethguad's Avatar
An SS Impala or a Honda?
Old May 15, 2005 | 04:58 AM
ALMXDUPINTEGRA's Avatar
I suggest anytime you add stuff to your car you always should reset the ecu.
Old May 15, 2005 | 06:58 AM
yrethguad's Avatar
Default Re: (ALMXDUPINTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">I suggest anytime you add stuff to your car you always should reset the ecu.</TD></TR></TABLE>
Agreed. When I got my car the idle fluctuated. The previous owner put on an intake and a glass pack and never reset the ECU. After the reset it's solid.
You can reset the codes using a scan tool or disconnecting power to the ECU for a minute via disconnecting the negative terminal on the battery or taking out the ECU fuse. I understand you've already done it, but just for anyone else's reference.
If your check engine light was still on then yeah, it needs a reset to clear the codes.
Old May 15, 2005 | 06:59 AM
yeah..i replaced the o2 sensor...drove it for like 500 miles and when i went to check for the error code, it was still there----i didnt reset it, but i did now and its cool.
now that ive restted and drove it 300 miles (a tank), it hasnt appeared anymore.
i think the o2 sensor fixed check engine light number 1 and 43
Ek4drcindy
Mar 18, 2011 03:55 PM
eswaroop
Apr 8, 2004 03:37 PM
Fatty_1775
Aug 5, 2003 05:37 AM
Champ R
May 23, 2003 07:01 AM
00fbp
Aug 16, 2001 08:18 PM
