Resetting ECU
Old Jun 24, 2002 | 06:38 AM
B18Redline's Avatar
Default Resetting ECU
I have a 95 Integra, with i/h/e/NGK's and I have never reset my ECU. Should I??
I had been told in the past that resetting the ECU only applies to cars equipped with OBD2 or OBD3, but I am not sure if that is true or not.
If I do need to reset my ECU, does anyone know the proper procedure?
Thanks
Old Jun 24, 2002 | 06:49 AM
yellowbuffalo's Avatar
Default Re: Resetting ECU (topfuel007)
http://www.c-speedracing.com/faq.html
Old Jun 24, 2002 | 09:41 AM
JDMCRVTEC's Avatar
yeah do what he said
Old Jun 25, 2002 | 09:34 AM
B-series Assassin's Avatar
It depends how long you had your mods. If you had your mods for a while then you wont need to reset your ECU because it senses the difference in air flow and after a while fixes the problem. If you just get a new mod, then it's a good idea to reset the ECU.
Old Jun 25, 2002 | 09:36 AM
poison's Avatar
Default Re: Resetting ECU (JC)
Remove your NEGATIVE ( ground ) Battery cable... or remove the HAZARD fuse from your fuse box in your engine bay...
jerkof1
Aug 22, 2005 10:35 AM
SOHC_MShue
Oct 14, 2002 11:22 AM
