reseting computer
Old Oct 4, 2007 | 02:12 PM
turboteg90's Avatar
pm for noodz
Default reseting computer
how can i reset the ecu on my 90 gs integra,the car is turbo so if i do this will it affect the car
Old Oct 4, 2007 | 02:29 PM
hatchling37's Avatar
Default Re: reseting computer (turboteg90)
Holy cow. What do you mean reset the ECU? Why would you want to do that? What is your cause for doing this? You shouldn't have bought a car with a fair amount of modification if you don't know what the hell you're doing with it...
Old Oct 4, 2007 | 02:50 PM
turboteg90's Avatar
pm for noodz
Default Re: reseting computer (hatchling37)
no its because its runnin in safe mode,the car wont rev past 4000rpm when the check engine light is not on.
Old Oct 4, 2007 | 08:18 PM
6Spd_EJ6's Avatar
just disconnect the battery or take the ecu and back up fuse out the fuse box next to the battery... hope that helps...
Old Oct 4, 2007 | 10:40 PM
Destructive-'s Avatar
Default Re: reseting computer (OhMyEG)
disconnect the battery, wait a min. or two, connect it back, ecu reset =]
make sure you research some first tho, u wouldnt want ur setting to f up your tune (if it's tuned) it shouldnt......but research first.
Old Oct 5, 2007 | 07:25 AM
dickdragon's Avatar
fix the problem!!!!!!!! then reset it!
crxsi814
Jan 18, 2011 06:25 PM
bigslimdog
Mar 30, 2004 03:07 PM
Btothe3rdDegree
Aug 30, 2003 07:29 AM
