Replacing Seats
Old Dec 18, 2002 | 03:49 PM
CBR600OnTop's Avatar
Default Replacing Seats
I'm taking out my leather seats on an 01' teg and replacing them with some sparco's. Under the passanger seat there doesnt seem to be any wires. On the drier seat there is a wire tha is connected to the seats just by some tacs or something and runs under the carpet ad then into the seat. I was thinkin its for the seat belt sign but not sure. Can someone tell me what the wire is for and if i still need it for the sparcos. Thanks
Old Dec 18, 2002 | 04:10 PM
meatball01's Avatar
Default Re: Replacing Seats (TegTuner)
ya i took out my seats a lil while ago and that wire in my 96 ls was for the seat belt. it diconnects really easy just pops out
Old Dec 18, 2002 | 04:12 PM
Paste's Avatar
Loved
Default Re: Replacing Seats (ballenwitnobudget)
there is only a wire under the drivers seat...
Old Dec 18, 2002 | 04:17 PM
Default Re: Replacing Seats (paste)
Alright since the wire is for the seat belt when you take the seat out is it conected to the seat or do you take it off and keep it plugged in for the other seat. And i heard that if i unplug it it will reset my airbags or a part of my ecu for the seats belts? is this true
Paul
Old Dec 18, 2002 | 04:45 PM
-BlueGSR-'s Avatar
The wire is only on the drivers side and its for the reminder for you to BUCKLE UP!...the drivers side only h as this feature...the wire comes up from the floor board and plugs in to the wire attatch to the seat and seatbelt...you can just unplug it...
If you use the stocke seatbelt the wire should be attached to it and then you can plug it in to the floorboard wire...HTH
Old Dec 18, 2002 | 05:08 PM
basmasta7's Avatar
Default Re: Replacing Seats (GS-ssbp-R)
what color are the seats you're taking out? i might be interested in buying them if htey're tan
Old Dec 18, 2002 | 05:18 PM
GSRaCeRbOI's Avatar
like everyone said.. the wire on the driver side seat is for the seat belt reminder.. notice how when you start your car the seat belt reminder (on the dash) is illuminated.. then when you buckle your seat belt the light on the dash/the reminder goes off? thats what that wire going from the floorboard/carpet to the underside of the driver seat is...
it has a plug which you have to push down a pin (if I recall correctly) to disconnect the harness/wires from the floorboard to the plug on the underside of the seat... you can unbolt the seat (4 bolts) and tilt it to the side if you can't see it or figure it out.. it can also be done w/ the seat bolted down... either way...
FlewByU352
Jul 13, 2009 04:45 PM
darkid10
Nov 22, 2006 09:31 PM
uses0ap
May 11, 2006 05:15 PM
HONDA_CIVIC_HATCH_Boy
Feb 10, 2006 02:45 PM
pete332
Feb 11, 2004 05:49 AM
