removing the rear seat
Hi,
I'm having trouble removing the rear seat in my '94 rs and i dont want to break anything. the reason is because i want to run the amplifier wire down the middle and then under the rear carpet and then the rear seat. i need some directions, maybe a site with pics would be nice...
I can't find the 'how to' it anywhere...
Re: removing the rear seat (94RS)
Its so easy. Theres clips that hold the back pieces on where it folds down. Just pull those off, Next just slide it towards the middle and pull the metal thing out and take the whole back out. The bottom is just held on by a bolt.
I just want to remove the bottom, do I need to remove top also?
I need a little clearer explanation.
I see the bolt for the rear seat, you mean the one you can access through the back of the car, it's in the middle? I unscrewed it, but what now?
[Modified by 94RS, 7:02 PM 9/7/2002]
Re: removing the rear seat (paste)
there seem to be two hooks on the front side of the seat, one on each side of the car. I assume then that i dont need to take out the upper part. Do I pull it up from the front or rear, or does it matter?
