Removing Interior.
Old Nov 2, 2004 | 08:02 AM
dalam's Avatar
Default Removing Interior.
so I just found a dent on my car.
so the dent lies right there, I was wondering how do I competely take off the interior piece that lies right behind the drivers seat where the rear seat is.
I was only able to pry it off about half way until I reached the rear seat belt and thats where it stopped, am I suppose to remove any screws or anything to take the whole thing off? I'm trying to push the dent out myself..
Thanks for replies.
Old Nov 2, 2004 | 11:25 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Removing Interior. (dalam)
i believe you have to take out the tops of the rear seats, atleast on that side, and start from the back take out all the plastic clips (on dc's there are a cpl 10 mm bolts too) and then from the back push the panel towards the front then pull it out
Old Nov 3, 2004 | 08:49 AM
dalam's Avatar
Default Re: Removing Interior. (coptzer)
allright thanks, I'll get cracking on it.
Old Nov 3, 2004 | 10:19 AM
BlueTeg01's Avatar
USE Dry ICE to pull out the dent!!! Don't worry about stripping your interior!
Old Nov 3, 2004 | 10:25 AM
dalam's Avatar
Default Re: Removing Interior. (BlueTeg01)
I can just use dry ice?
because I am from Canada, its not exactly hot..I believe its snowing right now Haha.
thanks for the tip though.
Old Nov 3, 2004 | 12:01 PM
gser67's Avatar
yeah id like to hear how you use dry ice to pull dents out. what kind of dents does this work on. if there is a link on a write up that would be sweet because i have a few door dings i wouldnt mind getting rid of. thanks
Old Nov 3, 2004 | 12:06 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
I wouldn't trust anyone with Paul Walker as their avatar
Old Nov 3, 2004 | 12:35 PM
RicharDC4's Avatar
Default Re: Removing Interior. (gser67)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gser67 &raquo;</TD></TR><TR><TD CLASS="quote">yeah id like to hear how you use dry ice to pull dents out. what kind of dents does this work on. if there is a link on a write up that would be sweet because i have a few door dings i wouldnt mind getting rid of. thanks</TD></TR></TABLE>
DENTS & HAIL DAMAGE
Dry Ice will condense metal and thereby shrink small dents on your car. Place the Dry Ice on the inside of the dent if possible. Use heavy gloves and press flat sheet against dent. If it is not possible to get on the inside concave part of the dent, then using heavy gloves hold the Dry Ice so a corner can fit into the bottom lowest part of the cratered dent. Hold the Dry Ice until the metal is frosted at least 2 inches beyond the dent. Let the metal warm up (in the sun is the best) and repeat the procedure. Sometimes the dent will pop out perfectly. More often it will not be possible to get a flat smooth finish, but the dent will be reduced noticeably. Creased metal will still show the crease line but the dent will be far less pronounced. I have not seen any paint damage, but I'm sure if the paint is not strongly adhered, it could peel away.
http://www.dryiceinfo.com/other.htm
dvazriel
Honda CR-V & Element
Dec 13, 2016 08:07 PM
cadeMFjohnson
Jan 2, 2009 09:27 PM
bigBOI_92DA9
May 31, 2004 02:20 PM
accordselux
Apr 20, 2004 07:38 PM
lke2drvgsr
Jan 8, 2004 02:10 PM
