Removing DC2 trunk
Old Jun 30, 2008 | 09:52 PM
DJSurfer616's Avatar
Default Removing DC2 trunk
My 96 LS was involved in a hit and run when a lifted trunk hit my trunk and pusseh it in, luckily the only thing i need to replace is the trunk and the bottom molding. How do I remove the trunk and is there any easy way to redo the wiring for the new trunk?
Old Jul 1, 2008 | 07:38 AM
I Want An Si's Avatar
Default Re: Removing DC2 trunk (DJSurfer616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJSurfer616 &raquo;</TD></TR><TR><TD CLASS="quote">My 96 LS was involved in a hit and run when a lifted trunk hit my trunk and pusseh it in, luckily the only thing i need to replace is the trunk and the bottom molding. How do I remove the trunk and is there any easy way to redo the wiring for the new trunk?</TD></TR></TABLE>
so a Trunk hit your Trunk? was this an Elephant trunk? if not what kind of trunk was it?
Let me translate your question....
My 96 LS was involved in a hit and run when a lifted truck hit my trunk and pushed it in, luckily the only thing i need to replace is the trunk lid and the bottom molding. How do I remove the trunk lid and is there any easy way to redo the wiring for the new trunk lid?
Replacing a trunk lid is fairly simple and you probably dont need to replace any wiring, just take it off the old one before you take off the old trunk lid. Theres probably 4 bolts that hold on the trunk lid, you may or may not need to release the tension of the trunk tension bars before doing this...
Now lets Translate it in to what it sounds like youre saying
[B] I have zero grasp of the english language, please shoot meB]
/Flame
Old Jul 1, 2008 | 07:48 AM
HONDRETTI's Avatar
Default Re: Removing DC2 trunk (I Want An Si)
dude, IMPO that was totally unnecessary, the OP misspelled two words and on top of it, it was his first post ever. to the OP, welcome to honda-tech.
yes you'll have to disconnect the wiring and the strut bars before removing the 4 bolts that hold the hatch in place. youre gonna need an extra hand. the wiring is simple, just re-route it using the old hatch set up as a guide.
Old Jul 1, 2008 | 09:05 AM
Yea thanks for the warm welcome. I meant a TRUCK. But anyways alrite and any good advice on taking out the plastic inside the trunk so the wired are more accessible for the brake light and wiper?
Old Jul 1, 2008 | 12:05 PM
Neptronix's Avatar
Default Re: (DJSurfer616)
it's easy to take the plastic off. It has those stupid clip pins.
it's hard to get it back on. I need help with that too.. ha ha.
Mylinh
May 31, 2011 03:09 PM
mikeohyeah
Sep 4, 2008 09:59 AM
