Reducing interior exhaust noise
Old Jan 2, 2011 | 11:01 PM
jughead's Avatar
Default Reducing interior exhaust noise
I have a custom exhaust setup but its too damn loud for me....
Basically it boils down to what will reduce the exhaust noise the most for me the driver. Obviously inside and outside are almost the same but idk I'm thinking apexi ws2 or vibrant flat black mufflers. 300$ vs 120$ or so.
Is there a difference between the decibel output I'll hear?
engine:
jdm b18c, skunk2 intake manifold, aem cai, msd dist/wires
exhaust: 2.5 inch piping, random technologies high flow cat, resonator (dont know brand), skunk2 n1 muffler 2.5 inch
Old Jan 3, 2011 | 12:25 AM
JOE_DC4ever's Avatar
Default Re: Reducing interior exhaust noise
If you want a real quiet system, go with OEM
But if that isn't what your going for, you can go with a custom system with double resonators.
For you the driver, it will help if you put sound deadening material down under your carpet as well.
I have the Apexi WS2 on my GSR and it is almost too quiet for me, but it isnt my DD so i dont mind the noise when i do drive it.
Old Jan 3, 2011 | 02:08 AM
jughead's Avatar
Under the entire carpet? What would give more noise reduction, the muffler change or another resonator? Not going oem unless i really have to.
Old Jan 3, 2011 | 09:55 AM
Spawne32's Avatar
step 1 - line the inside of the car with edead45 or 85 and or carpet padding from home depot in key locations in the back of the car and behind the door panels/interior panels.
step 2 - magnaflow perforated core resonators
getting ready to install my exhaust which will consist of a catco 2.5" cat, 2.5" mandrel bent cat back, magnaflow 18" glasspack resonator, and dynomax superturbo muffler on the end.
Old Jan 3, 2011 | 10:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
As I found out the hard way, eDead 45/85 butyl sheets don't do jack for reducing interior road/exhaust noice (high frequency). The butyl is more for deadening low frequency vibrations. The eDead foam sheets is what you need for reducing high frequency noise infiltration into the cabin.
Old Jan 3, 2011 | 10:32 AM
Spawne32's Avatar
depends on where you put it, the butyl is good at reducing noise in places where you cannot afford to have thick foam padding
Old Jan 3, 2011 | 10:34 AM
Community Builder
I don't know, I lined the entire floor, front to back, side to side, rear side panels, door panels, and rear bulkhead with 125 s.f. of eDead 45 several years ago, even doubled it up in some places. Yet my car is still loud as ever inside. Even my 195/55-15 tires loud as FAWK on the highway.
I really need some of the foam stuff, like really bad.
Old Jan 3, 2011 | 10:38 AM
Spawne32's Avatar
well most of the noise actually comes from the fact that its a hatch, alot of it comes from the rear wheel wells and the trunk, so going super thick with the padding in those areas is where it counts the most, lining the door panels with the 45 made a huge difference in the sound that came through the doors for me, but still get tons of noise from the rear of the car, it also doesnt help that my rear interior panels are still loose..
Old Jan 3, 2011 | 07:23 PM
jughead's Avatar
Ok but a muffler change or resonator for a quick result?
Old Jan 3, 2011 | 07:32 PM
Spawne32's Avatar
muffler change ideally, and keeping your cat
Old Jan 3, 2011 | 11:04 PM
jughead's Avatar
alright but which one vibrant flat black or apexiws2?
Old Jan 3, 2011 | 11:10 PM
Spawne32's Avatar
apexi ws2 will be the quietest
Old Jan 3, 2011 | 11:42 PM
jughead's Avatar
ah by how much though? a nosehair? 200$ worth? Thats almost two more resonators.
Old Jan 4, 2011 | 04:44 AM
VTEC_PRODUCTION's Avatar
get the vbrant whisper resonator and vibrant flat black and it will be nice and quiet...
Old Jan 4, 2011 | 07:00 PM
jughead's Avatar
i assume you mean vibrant ultra quiet resonator, never heard of a whisper resonator
Old Jan 9, 2011 | 02:43 AM
my bad...thanks for the correction
Old Jan 9, 2011 | 04:03 AM
slimsdizz's Avatar
just get a twin loop muffler you can get a knockoff on ebay or find a used mugen on ebay if you want to maintain power have an awesome look and reduce noise get a twin loop
if you want super quite I've got a apexi muffler here you can pm me about very quite.
bgslash98
Jan 21, 2009 06:36 AM
axtran
May 27, 2006 12:15 PM
IntegraMastaz
May 4, 2006 06:41 PM
jvschlegel
Aug 1, 2005 06:14 PM
gotsmokedright2
Feb 18, 2005 07:46 PM
