Redlines and revlimits...
Old Nov 29, 2003 | 08:06 AM
Hites
Guest
Posts: n/a
Default Redlines and revlimits...
what are the stock redlines and revlimits of all of the trim levels of gen3 tegs? need to know this to figure out what redline and revlimit i should have for the 97 cl v6 that im buying; going to put some custom pistons and cams in her (probably just have itr spec cams).
Old Nov 29, 2003 | 09:20 AM
riceball777's Avatar
Default Re: Redlines and revlimits... (Hites)
gsr= 8,100
itr 8,400
ls 6,800
Old Nov 29, 2003 | 09:28 AM
Hites
Guest
Posts: n/a
Default Re: Redlines and revlimits... (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">gsr= 8,100
itr 8,400
ls 6,800</TD></TR></TABLE>
those are redlines not revlimits, right?
Old Nov 29, 2003 | 09:52 AM
wall of tvs's Avatar
Those are the redlines.
Old Nov 29, 2003 | 10:05 AM
Passaudi1.8t's Avatar
New User
Default Re: Redlines and revlimits... (wall of tvs)
Rev limits are as follows (I think)
GSR- 8200
ITR- 8600
LS- 7200
Old Nov 29, 2003 | 10:06 AM
Default Re: Redlines and revlimits... (Dr.FeelgooDC2)
GSR revlimit is 8300
Old Nov 29, 2003 | 11:11 AM
fiebru1119's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wall of tvs &raquo;</TD></TR><TR><TD CLASS="quote">GSR revlimit is 8300</TD></TR></TABLE>
watch out though because stock tachs tend to be pretty unaccurate. when i first got my car i would shift at exactly 8100 and i would fall out of the secondaries on the 1-2 shift. after some more runs it turns out i "redline" close to 8400 on the stock tach..
Old Nov 29, 2003 | 01:00 PM
patdemps's Avatar
Default Re: Redlines and revlimits... (fiebru1119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiebru1119 &raquo;</TD></TR><TR><TD CLASS="quote">
watch out though because stock tachs tend to be pretty unaccurate. when i first got my car i would shift at exactly 8100 and i would fall out of the secondaries on the 1-2 shift. after some more runs it turns out i "redline" close to 8400 on the stock tach.. </TD></TR></TABLE>
right on. stock tach isn't the most accurate thing out there, just like the speedo
Old Nov 29, 2003 | 04:30 PM
[ iLL ] iNt3GrA's Avatar
yeah stock tach it is 8,4 on a gsr i think it comes up as 8,2 on the vafc
Old Nov 29, 2003 | 05:47 PM
svtec's Avatar
L D E S
Default Re: ([ iLL ] iNt3GrA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ iLL &raquo;</TD></TR><TR><TD CLASS="quote"> yeah stock tach it is 8,4 on a gsr i think it comes up as 8,2 on the vafc</TD></TR></TABLE>
thanks that made perfect sense.
Old Nov 29, 2003 | 06:37 PM
bub838's Avatar
sarasm?
Old Nov 29, 2003 | 07:55 PM
oMek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">what are the stock redlines and revlimits of all of the trim levels of gen3 tegs? need to know this to figure out what redline and revlimit i should have for the 97 cl v6 that im buying; going to put some custom pistons and cams in her (probably just have itr spec cams).</TD></TR></TABLE>
itr cams in a v6? i know the more displacement that motor has the lower the redline i think. the h22a is like 7600 i think. and the v6 should be lower than that
Old Nov 29, 2003 | 09:02 PM
Hites
Guest
Posts: n/a
Default Re: Redlines and revlimits... (oMekoneDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
itr cams in a v6? i know the more displacement that motor has the lower the redline i think. the h22a is like 7600 i think. and the v6 should be lower than that</TD></TR></TABLE>
no no no, just the specs of each cam lobe, but that wont work since i just found out the 3.0 cl is sohc; i did find out that the cams off of the 03+ 3.2 cl-s will work in the 3.0 cl, so that should save me a lot of cash. yeah, the 3.0 cl has a 5500 redline ; thats just sad. im gonna see if i can up that to 7k; nothing too extreme, but enough to get me 300 hp and be very streetable after everything is said and done.
Old Nov 29, 2003 | 09:51 PM
oMek's Avatar
no no no, just the specs of each cam lobe, but that wont work since i just found out the 3.0 cl is sohc; i did find out that the cams off of the 03+ 3.2 cl-s will work in the 3.0 cl, so that should save me a lot of cash. yeah, the 3.0 cl has a 5500 redline ; thats just sad. im gonna see if i can up that to 7k; nothing too extreme, but enough to get me 300 hp and be very streetable after everything is said and done.</TD></TR></TABLE>
ok got ya, i didnt understand the first post to good. hope you enjoy the 3.0, i hade a 04 3.5 maxima for a month and when i wint back to my gsr i relized how slow it really was
Old Nov 29, 2003 | 10:05 PM
Hites
Guest
Posts: n/a
ok got ya, i didnt understand the first post to good. hope you enjoy the 3.0, i hade a 04 3.5 maxima for a month and when i wint back to my gsr i relized how slow it really was</TD></TR></TABLE>
i see you met mr. displacement and mr. torque. i have a few people saying that upping the cr from 9.4:1 to 11:1, putting in more aggressive cams, evening out the af ratio, and raising the redline from 5500 rpm to 7000 rpm will only yield a 35 to 50 total hp increase; but thats seeming like some bs to me. does drastic changes like that to a 3.0 liter engine producing minimal gains such as those seem correct? im thinking theyre stuck in their small displacement world (3 liters, big displacement; whooda thunk it?).
Old Nov 29, 2003 | 10:13 PM
threatcon13's Avatar
New User
i see you met mr. displacement and mr. torque. i have a few people saying that upping the cr from 9.4:1 to 11:1, putting in more aggressive cams, evening out the af ratio, and raising the redline from 5500 rpm to 7000 rpm will only yield a 35 to 50 total hp increase; but thats seeming like some bs to me. does drastic changes like that to a 3.0 liter engine producing minimal gains such as those seem correct? im thinking theyre stuck in their small displacement world (3 liters, big displacement; whooda thunk it?).</TD></TR></TABLE> Actually that sounds about right. Are you getting a 97 3.0 cl? A co-worker of mine has one of them, and we've looked for aftermarket parts...be forewarned..there are none except an obx header and comptech header. Are you 100% sure that the cl-s cam will drop right in?
Old Nov 29, 2003 | 10:43 PM
Hites
Guest
Posts: n/a
Default Re: Redlines and revlimits... (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> Actually that sounds about right. Are you getting a 97 3.0 cl? A co-worker of mine has one of them, and we've looked for aftermarket parts...be forewarned..there are none except an obx header and comptech header. Are you 100% sure that the cl-s cam will drop right in? </TD></TR></TABLE>
most parts that fit the 98-02 accord v6 (same engine ) fit the 97-99 cl. tsudo makes an exhaust thats like an apexi n1, but it is a dual exhaust with 3.5" outlets on the mufflers; very nice. im never 100% sure about anything, but the fellers on http://www.acura-cl.com say so and im taking a wild guess that they know about the acura cl . you dont know what looking for aftermarket parts is like until you look for parts for a 98 mercury mystique
Old Nov 29, 2003 | 10:48 PM
oMek's Avatar
can i ask why your selling the teg and getting a cl?
i almost beat a cl-s in my 2.2 sohc accord, not sure what year the cl-s was
Old Nov 30, 2003 | 03:11 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">can i ask why your selling the teg and getting a cl?
i almost beat a cl-s in my 2.2 sohc accord, not sure what year the cl-s was</TD></TR></TABLE>
a cl-s is at least an 00. my friends offering his 3.0 cl premium for $2500 to me, which is a great price considering its worth about twice that much. i also want something different (that is the plague of my family; we struggle to keep a single car for just a year), and the cl 3.0 has somethings that my teg will NEVER have: torque and luxury. if youre so concerned about my teg, why dont you give her a good home ? just got pics of her and you can find her in my sig.
Old Nov 30, 2003 | 03:32 PM
integraL's Avatar
Default Re: (svtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ iLL &raquo;</TD></TR><TR><TD CLASS="quote"> iNt3GrA]yeah stock tach it is 8,4 on a gsr i think it comes up as 8,2 on the vafc</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">thanks that made perfect sense.</TD></TR></TABLE>
he's saying when a VAFC reads the RPMS at 8,200....the tach reads 8,400.
Old Dec 1, 2003 | 05:36 AM
mrmonk's Avatar
Default Re: (integraL)
i dunno about you guys but my fuel cut off is as soon as i rev past 8100.
Old Dec 1, 2003 | 09:57 AM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">
he's saying when a VAFC reads the RPMS at 8,200....the tach reads 8,400.</TD></TR></TABLE>
i know what he is saying.
most laymen would look at that and say "what the hell?" thats all.
MR Dan
Nov 6, 2005 06:08 PM
1.8EG-T
May 13, 2005 04:16 AM
kaj
Feb 5, 2005 11:16 PM
jdm.ej
May 4, 2004 05:17 AM
p1ccoloz
May 20, 2003 09:08 PM
