Rear wiper delete problem
Old Jun 21, 2014 | 11:18 AM
migsr01's Avatar
Default Rear wiper delete problem
I searched honda-tech on how to do the rear wiper delete. Very easy to remove. I ordered the oem rubber grommet part #91617-sb6-000. I removed the wiper assembly and when i install the rubber grommet it doesnt fit. It goes right through the hole in my hatch glass. The window is oem honda and the wiper assembly grommet fits snug and works fine. What is the problem here? Thank you
Old Jun 21, 2014 | 12:20 PM
vartok's Avatar
Default Re: Rear wiper delete problem
Not sure what the problem is, but what are you planning on doing with the old wiper assembly? Mine was deleted when I picked up the car and was looking into putting it back
Old Jun 21, 2014 | 12:24 PM
migsr01's Avatar
I was planning to hang on to it. Right now i cant take it out cuz i will have a hole there.
Old Jun 21, 2014 | 01:43 PM
fcm's Avatar
fcm
Old Fart
You have the wrong "grommet" 94
Old Jun 21, 2014 | 02:53 PM
migsr01's Avatar
Any idea on the "right" one? Part number
Old Jun 22, 2014 | 01:59 PM
migsr01's Avatar
Any ideas? Why doesnt this plug fit mine but works for everyone else?
Old Jun 22, 2014 | 02:02 PM
B_Swapped93's Avatar
Get a password jdm one you have the wrong part, I have a thread with the parts numbers can't remember how old i'll try and find it.
Old Jun 22, 2014 | 02:57 PM
migsr01's Avatar
Yea let me know if you find it. I dont want to spend 35 for the passwordjdm one if i font have to.
Old Jun 22, 2014 | 04:53 PM
it's supposed to be smaller it's not a tight fit on mine either but does stay in.
Old Jun 24, 2014 | 06:39 PM
migsr01's Avatar
Thats the same plug i have. The bottome ring/lip goes right inthe hole with no resistance. Do i epoxy or silicone it in the hole? Or any other options before i put the panelse back in and say screw it
Old Jun 24, 2014 | 07:19 PM
you could do some super glue on it I suppose, strange EVRYONE uses that plug with no issues.
Old Jun 24, 2014 | 08:20 PM
migsr01's Avatar
I took the one out of the firewall near the battery but it fits the same way. Is there another oem setup thats 3 pieces with a nut and bolt or something?
Old Jun 25, 2014 | 12:47 PM
fcm's Avatar
fcm
Old Fart
Run a thin bead of black silicon around the underside of the "lip", plug into hole in glass, let silicon set dry, use thumb to "roll" off any "overflow", your done.
FYI, there is no "wiper delete" grommet, [dummy plug], what is being sold are just dummy grommets, you can probably do better at a local boneyard, [PicknPull] just look for dummy plugs in other then Honda/Acura cars, you can most likely find one that is a perfect fit, one that actually, "snaps" into place tight enough that it would need to be forced out. 94
Old Jun 26, 2014 | 09:39 AM
gsrbanger's Avatar
Did u also get the bolt and bolt seal when u ordered the rubber grommet? If not u also need
90301-sr3-000. Bolt seal,
90108 or 90156-sr3-000 Bolt.
It will all make sense if u have those parts along with 91317-sb6-000
Old Jun 26, 2014 | 10:10 AM
donut.'s Avatar
92-95 Civic hatchbacks that didn't come with a rear wiper have a metal plug, a rubber grommet, and bolt/washer.
Looks like these are the part numbers
Old Jun 15, 2018 | 12:32 AM
steadysupreme's Avatar
im having the same problem. Have this 91617-sb6-000 which everyone uses it fine. The under lip is not big enough to grip onto the glass.
Old Jun 25, 2018 | 05:56 AM
Jimmy's Avatar
Global Moderator
Use a bead of black silicone, that’s what I had to do..
E-Money
Jan 20, 2011 07:15 AM
dj-t
Feb 8, 2009 07:51 PM
Kantot
11
Jun 9, 2007 06:13 PM
sundownz
Oct 9, 2006 02:11 AM
Heisdan
Aug 16, 2003 07:19 AM
