Rear Trailing Arm Interchangability - HELP
Old Feb 1, 2008 | 11:02 AM
Snizzoop's Avatar
Default Rear Trailing Arm Interchangability - HELP
What other Honda chassis share the same/similar RTA as the DA?
As far as I was aware, I thought that all 90-01 Integra and 92-00 Civic RTAs were interchangable.
I'm being informed by an individual that I might have alignment issues with "newer" RTAs. His arguement is that EFs needed to use DA RTAs for the rear disc conversion, and that EG/EK/DC RTAs don't work.
Please post any info you might have.
Thanks.
Old Feb 1, 2008 | 01:51 PM
BlueIntegraBoy's Avatar
Default Re: Rear Trailing Arm Interchangability - HELP (Snizzoop)
All 88-00 Civic and 90-01 Integra RTAs are interchangeable. The only difference between the DA RTAs and the other ones is the RTA bushings. The DA RTA bushings have a larger diameter than 88-00 Civic and 94-01 Integra RTAs. However, if you are looking to replace your DA RTAs with any of the above, you won't have any compatibility issues. It will bolt up fine.
Old Feb 3, 2008 | 07:45 AM
Snizzoop's Avatar
Bump for more reassurance.
hondaOchibi7
Mar 9, 2011 10:23 AM
Davidkak
15
Jan 11, 2011 02:29 PM
cangrin
Jan 20, 2009 09:50 AM
Adrenaline_Racing
Nov 9, 2005 04:24 PM
