Rear Panel Replacement
Old Jan 8, 2005 | 07:46 PM
dr_latino999's Avatar
Default Rear Panel Replacement
We just recently picked up a 94 LS as a project and seems to have had a minor "run-in" with some type of object in the rear. The result was that the rear panel that goes under the lights but above the bumper is shot to hell.
Is there any way to replace this peace without cutting and welding?
Old Jan 8, 2005 | 07:55 PM
neogenesis2004's Avatar
Default Re: Rear Panel Replacement (dr_latino999)
its a bolt in part. Im actually also looking for a new one. Youll have to remove the rear interior panel and both of the interior quarter panel pieces to take it off. It is held on by 8 8mm nuts that are painted the same color as the car. the only other bolts on the rear are the bronze taillight nuts and the 4 black bumper bracket nuts.
To take off the rear panel just locate all the little clips that hold it on. To remove them you push in on the circle in the center and then remove the entire thing. Do that to all of them and the panel just lifts out.
To remove the side panels you have to fold down the rear seats, take out the speaker grills, and take off the little panels that cover the rear suspension tops. There are 2 bolts on the rear end of both panels and 2 screws near the front of both panels. The rest of the panels is held on by retention clips, so dont be afraid to pull.
Once all that is out you can easily unbolt and part on the back of the car.
-Brian
Old Jan 8, 2005 | 07:56 PM
b-power's Avatar
i've seen people selling that piece here on H-T and Team-Integra.net. just have to search around
Old Jan 8, 2005 | 08:53 PM
solk1dd's Avatar
you can buy that at a junkyard place.
I've taken that out before, all you have to do is take out your rear panels and it shows it all.
It's like taking off a rear bumper.
Old Jan 8, 2005 | 09:30 PM
cnydc2's Avatar
Default Re: (solk1dd)
It is only one piece, a couple bolts to remove and it is off. You could prolly get that peice preety cheap at a automotive paint supply shop. Try that or a junkyard.
Old Jan 8, 2005 | 10:02 PM
RidinStock's Avatar
Default Re: (cnydc2)
I messed up that piece on my car too (although it was a g2) and the removal was pretty simple. I never found a replacement though... so I wish you the best of luck. For me, it was hard to find.
Old Jan 9, 2005 | 05:42 AM
Default Re: (RidinStock)
We have a donor car in a salvage yard waiting, we just wanted to make sure it would be an easy removal. Thanks
Old Jan 10, 2005 | 11:09 PM
calxtreme's Avatar
yup...easy removal, just bolts.
Old Jan 11, 2005 | 10:38 AM
KLeSe's Avatar
Default Re: (calxtreme)
just got mine from a junkyard $40.
Old Jan 11, 2005 | 11:01 AM
Marauder's Avatar
Default Re: (Hbadge4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hbadge4Life &raquo;</TD></TR><TR><TD CLASS="quote">just got mine from a junkyard $40.</TD></TR></TABLE>
What junk yard did you go to?
Old Jan 14, 2005 | 09:27 AM
KLeSe's Avatar
Default Re: (Marauder)
San Diego, Ecology
D16Z6racing
Jan 18, 2011 08:05 AM
goldenarches69
Oct 3, 2007 04:00 AM
taken roads
Honda Civic (2001 - 2005)
May 2, 2006 10:00 AM
my merc 4
Apr 12, 2004 10:59 AM
Chip398193
Jan 16, 2002 08:59 AM
