rear DA toe problem
Old Dec 20, 2012 | 02:05 PM
unrestrictedkc's Avatar
Default rear DA toe problem
so here my problem ive got a 92 DA integra GSR ive got a toe wear problem thats causing me to wear threw tires 5-8k miles both sides are about a degree pointed out and the adjustment arms are adjusted all the way in any
ideas on what could be the problem BTW its not been wrecked and theirs no suspension damage
Old Dec 20, 2012 | 02:46 PM
kchungb17a's Avatar
Default Re: rear DA toe problem
You have a DB2. How many miles? Is this a new problem? Are you the original owner? If not, how do you know it hasn't been in an accident?
What kind of suspension do you have?
How are your tires wearing? Pics would help.
Suspension problems are almost always related to a bent body or suspension components.
Old Dec 20, 2012 | 03:30 PM
im not the original owner its 273k on it the suspension is mostly stock coilovers all the way around and a camber kit in the rear
Old Dec 20, 2012 | 04:00 PM
kchungb17a's Avatar
Did you take this to an alignment shop? Did the tech inspect all the bushings and arms? Are the other adjustments within spec? When I replaced my trailing arms on my DC2, it had 160k miles on them and the bushings were starting to tear.
BTW, camber kits are rarely needed on a street car. Usually on a 2.5"+ drop. And if you're that low, you're too low.
HFP-EP3
Mar 22, 2010 07:09 PM
roycivic92
Suspension & Brakes
Jun 23, 2008 08:11 PM
latrungkiet
Jul 5, 2005 03:33 PM
George H
Jul 12, 2001 12:00 PM
George H
Jul 11, 2001 07:07 PM
