Random beeping in cabin
Old Sep 23, 2003 | 04:21 PM
integra-evan's Avatar
Default Random beeping in cabin
Lately, I have been getting a beeping while I am driving that sounds like the type of beeping when you first start the car (I have a 1990 Teg RS by the way) and am not sure what it is. No idiot lights come on, and they car performs as usual when it happens. Sometimes it beeps in a pattern, other times not. I was wondering if anybody had any suggestions of what it is, or if it has happened to you. Thanks!
Old Sep 23, 2003 | 04:23 PM
VTECorona's Avatar
Default Re: Random beeping in cabin (integra-evan)
It may be from your maintenance required light. is it on? if so reset it, there is a little blue button to the right side under your steering column. just a guess
Old Sep 23, 2003 | 04:28 PM
Default Re: Random beeping in cabin (VTECorona)
no lights come on when it happens
Is there a blue button like that in the 1990?
Old Sep 23, 2003 | 06:27 PM
skunkintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-evan &raquo;</TD></TR><TR><TD CLASS="quote">Is there a blue button like that in the 1990?</TD></TR></TABLE>
no
so about the beeping.... does ur DA have that nasty cabin leak.. get water on ur floorboards??
if so-- could be an electrical problem?--
its like the seatbelt beep right??
Old Sep 23, 2003 | 06:42 PM
ILOVEGIRLS's Avatar
Default Re: Random beeping in cabin (skunkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">
no
its like the seatbelt beep right??</TD></TR></TABLE>
mu friend has this issue with his crx..how do u fix this ish?
Old Sep 24, 2003 | 11:01 AM
Default Re: Random beeping in cabin (ILOVEGIRLS)
I fixed my leak when i first got it, sealed up the bottom of the widshield, where the original black sealant was worn. That worked.
the beep is the same beep as either the seatbelt beep or ignition beep. I have no clue why its doing it!
Old Sep 28, 2003 | 06:07 PM
yes
sce310
Honda Civic (2006 - 2015)
Oct 8, 2006 11:20 AM
plude2001
Jun 6, 2004 02:39 PM
Xumarius
Jul 11, 2003 03:27 PM
