Radiator Question
Old Jan 10, 2010 | 05:03 PM
Alex M.'s Avatar
Default Radiator Question
Ok I just bought a new radiator for my 90' DA. The new one has two brass tubes at the bottom, but the old one(radiator) doesn't have that. Do I just plug those fittings or what? I checked and there are no lines in the bay that could connect to them. Is this something for a different year Integra? I have to make some brackets at work to mount the fans because of course the holes do not match up. Thanks in advance to all.
Name:  Old Radiator.jpg
Old Jan 10, 2010 | 05:30 PM
all-mtr-teg's Avatar
Default Re: Radiator Question
Just leave them capped. Those are optional oil cooler lines for automatic transmissions. If the fans don't line up to the radiator brakets, take it back, the fans should install right in without any mods or fabrication work.
Old Jan 10, 2010 | 06:04 PM
Alex M.'s Avatar
OK cool. The caps that are on there are really soft, do you mean those? They won't be able to hold any pressure for sure.
Old Jan 10, 2010 | 06:29 PM
seanbev24's Avatar
It's a seperate section of the radiator so you can just leave it alone. No coolant or pressure gets to those fittings.
lmike6453
Oct 14, 2008 02:03 PM
PatrickGSR94
Jul 6, 2005 11:15 PM
SpoOoLin EK
Jun 15, 2005 09:54 AM
VinceVTEC
Apr 25, 2004 03:19 PM
boost killz
Sep 24, 2001 07:23 AM
