Radiator Problem, help
Old Apr 29, 2006 | 11:03 AM
R81_DC2's Avatar
Default Radiator Problem, help
Today i park in front of the barbershop and i get out and i see smoke coming from my front grill by the radiator. IT was leaking antifreeze , so i checked the hoses and there fine i think my radiator is fucked. SO i was wondering if anyone could reccomend me some nice racing radiators that are not overly expensive but perform better then stock. if someone could provide me links or some suggestions it would be greatly appreciated.
Old Apr 29, 2006 | 11:13 AM
Lan's Avatar
Lan
Default Re: Radiator Problem, help (GullyFromJerz)
I dunno how much they cost but Koyo and Fluidyne seem to be really popular. You can buy and aftermarket replacement for about a $100 bucks though.
Old Apr 29, 2006 | 11:21 AM
b00sted4dr's Avatar
Default Re: Radiator Problem, help (Lan)
I just bought the one from radiatorbarn.com for a gsr and it was about 130 shipped. Seems like alot of people on here recommend them.
radiator barn
Old Apr 29, 2006 | 01:16 PM
R81_DC2's Avatar
Default Re: Radiator Problem, help (b00sted4dr)
hmm is the radiatorbarn one better then OEM? also what would u guys suggest save up for the racing one which is probably gonna cost me around 300-400 or go with the radiator barn one for 130?
Old Apr 29, 2006 | 01:29 PM
Lan's Avatar
Lan
I wouldn't say it is better than OEM. If you have the money that go with an after market radiator. I have an H22 swap in my teg but I use the stock GSR radiator with no problems. I would invest in a different thermostat and switch if cooling is an issue with your car.
Old Apr 29, 2006 | 01:46 PM
R81_DC2's Avatar
i dont i was going to go turbo pretty soon and like if i buy koyo or fluyidine its gonna set me back like 300-400, and i wasnt going to go higher then 8 PSI tuned, so like im stuck now, do you know any other aftermarket radiators that are not that highly priced, like around 200 or something, because i think 300 and 400 is way too much for now.
Old Apr 29, 2006 | 01:57 PM
Lan's Avatar
Lan
With a stock radiator, thermostat and switch (Mugen has some lower temp stuff that kicks ***) you won't need Fluidyne or Koyo. Check out http://www.kingmotorsports.com for the Mugen stuff. You'll be at right about $250 with a new OEM style radiator Mugen switch and thermostat. You can also get cheaper thermostat that will engage at lower temperatures so overheating won't be an issue.
Old Apr 29, 2006 | 02:07 PM
R81_DC2's Avatar
so i can buy that radiatorbarn radiator and buy the mugen thermostat/switch and ill be set? ?
Old Apr 29, 2006 | 02:09 PM
Lan's Avatar
Lan
Yep. I know guys who boost with EG radiators. They use them because often times the turbo system you use is too big to fit.
Old Apr 29, 2006 | 02:14 PM
R81_DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">Yep. I know guys who boost with EG radiators. They use them because often times the turbo system you use is too big to fit.</TD></TR></TABLE>
thanks , thats what im gonna do. it'll come out cheaper and hopefully more space for my intercooler.
Old Apr 29, 2006 | 02:15 PM
Lan's Avatar
Lan
Awesome. Post up some pics when you are done!!
Old Apr 29, 2006 | 04:28 PM
teg racer 877's Avatar
Wait! I just picked up my koyo halfsize from a sponsor for like $290, not to expensive and Im sure its better than the oem halfsize, I think his name was TC motorsports.
Oh: nice lookin teg you got there, I never thought 4 spokes could look so good.
Old May 1, 2006 | 03:36 PM
R81_DC2's Avatar
Default Re: Radiator Problem, help (teg racer 877)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 &raquo;</TD></TR><TR><TD CLASS="quote">Wait! I just picked up my koyo halfsize from a sponsor for like $290, not to expensive and Im sure its better than the oem halfsize, I think his name was TC motorsports.
Oh: nice lookin teg you got there, I never thought 4 spokes could look so good.</TD></TR></TABLE>
are you sure it was TC motorsports, i searched in the Member list and no results. Thanks btw, cant wait to slap that si-vtec lip on their, with my SIR fogs. :]
Old May 1, 2006 | 05:48 PM
Just found the thread for you, his member name is TCMotorsports2, spelled just like that.
Old May 1, 2006 | 07:25 PM
MasterKwan's Avatar
My 1/2 size wasn't big enough to keep my non-boosted R motor cool on the track. I'd get temp creep and have to run the heater to keep the temp down. Just something to think about. The 'stat has no affect on total effectiveness of the radiator. Once they're open, they all flow the same amount of fluid. Lower temp 'stat might improve HP and reduce detonation but, that's about it.
Old May 2, 2006 | 11:27 AM
Default Re: Radiator Problem, help (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">My 1/2 size wasn't big enough to keep my non-boosted R motor cool on the track. I'd get temp creep and have to run the heater to keep the temp down. Just something to think about. The 'stat has no affect on total effectiveness of the radiator. Once they're open, they all flow the same amount of fluid. Lower temp 'stat might improve HP and reduce detonation but, that's about it. </TD></TR></TABLE>
what kind of rad. was it? with my koyo halfsize I can drive it hard and no creep from the guage, only creeps a little when in traffic on hot days, and I got no fan on it. Im gonna put one on in a few weeks when im boosted tho. just to be safe.
Old May 3, 2006 | 03:01 PM
R81_DC2's Avatar
If i buy that koyo radiator , will i be able to use my A/C?
Old May 3, 2006 | 03:58 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Half core off ebay sounds about what your lookin for... the thing with radiators is they dont really out perform stock that much. Really just either have a higher fluid capacity or maybe cool a fuzz more. Ive seen some insane high hp cars runnin ebay half cores... i wouldnt recommend a high priced radiator.
Old May 3, 2006 | 06:41 PM
Default Re: Radiator Problem, help (ForceFed_Motorsports)
yea but ive heard the ebay ones can crack over time, plus the aluminum ones on ebay are like $150 + shipping, I would rather spend some more and get a koyo so I know it wont crack (or less likely)
Old May 4, 2006 | 06:55 AM
Thats true, its probably a better investment. Although, turbo will probably blow your engine before your radiator will crack, just a thought.
Old May 4, 2006 | 07:16 AM
93_teg_CT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 &raquo;</TD></TR><TR><TD CLASS="quote">yea but ive heard the ebay ones can crack over time</TD></TR></TABLE>
I've heard the same thing with stock ones.
Old May 4, 2006 | 11:39 AM
Default Re: Radiator Problem, help (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">
I've heard the same thing with stock ones.</TD></TR></TABLE>
thats why I have a koyo
Old May 4, 2006 | 11:57 AM
00IntegrAllmotoR's Avatar
HT Black OPs
half-size ebay FTW
Old May 5, 2006 | 09:06 AM
Default Re: Radiator Problem, help (00IntegrAllmotoR)
Ebay half core all the way, cheap and others have had success with them.
Old May 5, 2006 | 09:55 AM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted4dr &raquo;</TD></TR><TR><TD CLASS="quote">I just bought the one from radiatorbarn.com for a gsr and it was about 130 shipped. Seems like alot of people on here recommend them.
radiator barn </TD></TR></TABLE>
+1
bought the all-metal version of the OEM radiator (stock has plastic caps for the top and bottom). you need nothing more as long as your radiator fan works properly. getting a race radiator is a waste of money unless you're going for $Bling$ for whatever reason. No conversion, no worries about fitment, and easy install.
just get the one from radiator barn
edit: from order to my door was about 2 days! great company $120+ shipped to my door
Modified by Sijray21 at 3:22 PM 5/5/2006
