radiator fan problem
Old Dec 13, 2012 | 08:26 AM
jdmsterds's Avatar
Icon2 radiator fan problem
my radiator fan is not working i have a 98 gsr with a ls swap in it, and i checked the fan itself if its working (i jumped a wire to the battery and it turns on) so what could be the problem? help me asap! thanks
Old Dec 13, 2012 | 08:59 AM
michaelcal121's Avatar
Default Re: radiator fan problem
Does the wire(s) from the connecter that conects to the fan conector split anywhere or is it not connected properly to the wiring harness from when you did the swap?
Old Dec 13, 2012 | 10:07 AM
teamkosmos's Avatar
Coolant sensor! You can put it direct by the plug if you want
Old Dec 13, 2012 | 12:09 PM
kchungb17a's Avatar
Is the temping gauge showing hot? If it is and the fans don't come on, carefully check for a big difference in temp between the upper and lower radiator hoses. If one hose is cool enough that you can get your hand around it but the other hose is so hot that you can barely touch it, you probably have a bad thermostat. That would cause your fans to not turn on.
Old Dec 13, 2012 | 12:59 PM
dsmchad's Avatar
Sorry if the 98 isn't the same as the older ones, but if the fan temp switch is in the bottom of the radiator like the older ones, and old radiator can build up goop in the bottom completely covering the sensor not allowing enough heat against it to turn it on.
Have you tested for a bad relay?
Old Dec 13, 2012 | 01:37 PM
kchungb17a's Avatar
Fan switch is in the head.
If the fans come on with the AC then it is likely either the thermostat or the fan switch.
loup05
Dec 11, 2008 04:43 PM
blue_dlb
Dec 19, 2004 09:20 AM
leadtrum
Nov 23, 2004 04:56 AM
Mattyg2
Jun 1, 2004 02:46 PM
joel
Oct 17, 2001 09:54 PM
