quick question: is there a difference between b18a and b18b crank pullies?
Old Oct 8, 2007 | 08:55 PM
chadmasterc's Avatar
Default quick question: is there a difference between b18a and b18b crank pullies?
I wanna run a little more boost with my jrsc setup. about to buy one and want to make sure they are the same.
Old Oct 8, 2007 | 09:07 PM
LordAphotic's Avatar
i know most years of the g2 have a different kind of belt a serpentine one i believe... and then 2 regular belts....
have you considered a b20b crank pully? its much bigger than the LS and ive herd of lots of people using them on their superchargers to increase boost.
Old Oct 9, 2007 | 06:32 AM
Default Re: (LordAphotic)
the b20 one would put me at about 9psi, Im gonna wait till I can intercool it to run that much boost.
So i need an earlier gen version ls pulley, thanks for the reply.
Old Oct 9, 2007 | 06:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm pretty sure that NO b-series engines ever had a serpentine belt. It had 3 separate belts for alternator, A/C compressor, and power steering pump.
Sons Acura lists different part numbers for the B18A and B18B crank pulleys, so I would guess they are probably different.
Dave_Dc2
Oct 21, 2008 10:38 AM
chadmasterc
Oct 10, 2007 05:14 PM
1hottEG6
Apr 2, 2003 07:31 AM
Shark Tank
Mar 19, 2003 12:17 PM
