Quick Question (searched)
Old Nov 16, 2006 | 09:49 AM
BoltonGSR's Avatar
Default Quick Question (searched)
I am takin the head off my gsr in the helms manual it says remove the driver side engine mount, the top one... Am i supposed to use the something to support the motor if im removing this mount? Dumb question i know. but Im a noob, but i just wanted to be sure...
Old Nov 16, 2006 | 11:07 AM
BoltonGSR's Avatar
Default Re: Quick Question (BoltonGSR)
bump?
Old Nov 16, 2006 | 11:45 AM
95 integra's Avatar
I dont think you have to take that mount off....you do if you want to replace the timing belt, but just to take the head off, you can leave it on.
Old Nov 16, 2006 | 12:35 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Quick Question (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">I dont think you have to take that mount off....you do if you want to replace the timing belt, but just to take the head off, you can leave it on. </TD></TR></TABLE>
agreed...but if you want to take it off go for it, but you should always support the engine when doing so, better safe than sorry
Old Nov 16, 2006 | 01:26 PM
95 integra's Avatar
Default Re: Quick Question (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
agreed...but if you want to take it off go for it, but you should always support the engine when doing so, better safe than sorry</TD></TR></TABLE>
Yea, when I do the timing belt I put something under the engine to help support it...its not like the motor is going to fall out, but you do run the risk of tearing another mount, especially the lower one.
Old Nov 16, 2006 | 08:36 PM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">I dont think you have to take that mount off....you do if you want to replace the timing belt, but just to take the head off, you can leave it on. </TD></TR></TABLE>Well dont i have to remove the timing belt to remove the head? Im havin' a blast with that fuckn crank pulley bolt, thanx for the replies
Old Nov 16, 2006 | 09:37 PM
95 integra's Avatar
Just have to loosen the tensioner and take the belt off the cam gears....which sometimes can be done just by sliding it off....however I prefer just to loosen the tensioner. You can leave the crank pulley on and just use the timing mark on it and the lower cover to find TDC.
hotsuma23
Feb 11, 2007 05:09 PM
Ridinobryan
14
Feb 11, 2007 12:34 PM
..::91TEG-G2::..
Dec 14, 2005 04:25 PM
Elvis1977
Nov 12, 2003 07:13 AM
