quick question.
Old Mar 13, 2006 | 09:58 PM
god.loves.ugly
Guest
Posts: n/a
Default quick question.
should I replace the gasket if I pull my valve cover off? or will it be okay?
Old Mar 13, 2006 | 10:02 PM
viet_boi_racin's Avatar
Default Re: quick question. (xDantex)
Its recomended that you do. But if its not dried up and cracking. you can wipe it clean and reuse it. i've done it many times.. works fine.
Old Mar 13, 2006 | 10:16 PM
crxnj's Avatar
Default Re: quick question. (viet_boi_racin)
I would do it if it hasnt been done yet and if the motor is old with higher miles..The valve cover gasket with o-rings is pretty cheap..Just remember to put some sealer on the corners to prevent leaks and dont overtighten the bolts,,they break very easliy..
Old Mar 13, 2006 | 10:22 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: quick question. (Mr.speaker)
01 with 70k so it shouldn't be too bad but I think I'll do it just to be on the safe side
foowitdaredek
Mar 6, 2015 01:44 PM
GsDAteg
Jan 31, 2009 05:03 AM
porter
Feb 16, 2007 01:46 PM
Shake and Bake
Jul 9, 2006 04:52 PM
myridechanelle
Sep 11, 2005 04:14 PM
