Quick ECU Question
Old Apr 3, 2009 | 06:20 AM
The G2 Racer's Avatar
Default Quick ECU Question
I've got a b16 in my 93 GS-R still being run by the factory P61 ECU.
I'm swapping an ODB2 B18C into my car, I'm assuming it would be best to get a 94-95 GS-R P72?
A friend has a P06 and he's saying I can chip that with a GS-R base map and still have the motor running good.
Opinions?
Old Apr 3, 2009 | 08:13 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Quick ECU Question
a p06 would not have the board for secondaries, only way to get them is with p72 ecu
Old Apr 3, 2009 | 08:47 AM
Thanks.
I'll grab a p72 ecu then.
Old Apr 3, 2009 | 12:08 PM
racebum's Avatar
the 94-95 p72 is obd1, also do you have the wiring in place for everything on the motor? like the correct harness?
Old Apr 3, 2009 | 01:54 PM
nonsense's Avatar
The P06 can be chipped to work with VTEC and the IABs, or like the others said if you want stock use the OBD1 P72
Old Apr 3, 2009 | 03:02 PM
What do you mean?
My car is an ODB1 GS-R. Other then the dizzy, injector clips and alt on the ODB2 engine everything is the same.
Since it's a long block I will be swapping my alt and I have a new dizzy. Injector clips aren't an issue either.
Tsunami_racer
Aug 20, 2006 11:13 PM
Hotinteg
Mar 2, 2005 07:25 PM
crxste
Sep 1, 2004 09:46 AM
FerioVtec94
Apr 12, 2003 06:27 PM
