quick door replacement question
Old Aug 17, 2006 | 11:33 AM
ansay's Avatar
Default quick door replacement question ??
i have a 95 ls coupe with some damage to the driver door exterior. It has a dent beyond body work. any way i just wanted to verify something before i spent any money. From what ive read there are no MAJOR (aside from painted trim pieces) differences between doors of different trimlines (aside from 4door vs coupes)?
am i correct that doors off a 94 rs be a direct replacement?
also if i ripped the guts out of my ls door would the conversion to power windows and locks be an easy project?
thanks for the help HT
Modified by ansay at 12:50 PM 8/17/2006
Old Aug 17, 2006 | 11:49 AM
DC2 Mang's Avatar
Default Re: quick door replacement question (ansay)
the RS door skin will fit perfect, to my knowlegde all G3 integras have power windows, power mirrors, etc...
so it should be just a bolt up then plug and play job
Old Aug 17, 2006 | 11:52 AM
ansay's Avatar
Default Re: quick door replacement question ?? (ansay)
thanks for the quick reply
i appreciate the info
Modified by ansay at 8:40 PM 8/17/2006
Old Aug 24, 2006 | 03:15 AM
ansay's Avatar
hey guys i kinda need some more input here from any one that has knowledge here. Im FAIRLY certain that the RS model coupe doors do not have power locks. Im picking up a set of these doors for my 95 LS. The reason being that there are some dents on my LS doors that are beyond reasonable repair. What else will i need to fully convert the doors over. I will have all the working wiring and switches from my LS door. Do i need to swap out all of the guts or can i just modify the RS doors with a power lock actuator or something. thanks for the help HT. i appreciate any input.
Old Aug 24, 2006 | 04:49 AM
My95SlvrBlt's Avatar
You will simply need to remove and install all the components, and wiring from your door, to the RS. The only door which is diff, is the ITR, and its the outer skin which is different.
Old Aug 24, 2006 | 10:10 AM
gsr dood's Avatar
Default Re: quick door replacement question ?? (My95SlvrBlt)
rs does not have power locks.
Old Aug 24, 2006 | 12:01 PM
ansay's Avatar
Default Re: quick door replacement question ?? (gsr dood)
thanks for the confirmation
so what goes into getting power locks in those rs doors? do i need to swap all the guts over or is it just select pieces. thanks HT. any input on this is welcome.
Old Aug 24, 2006 | 12:03 PM
The actual lock, your linkage(i think) and theres a control module. Easier way is take ALL your ****, and put it in the new door. dont worry about window motor, but you will need to change your harness to it.
Old Aug 24, 2006 | 12:20 PM
ansay's Avatar
Default Re: (My95SlvrBlt)
thanks My95SlvrBlt
if i had the option of picking up gsr doors instead would that be a direct swap? or would i still need to do any swapping of harnesses or guts in the process???
thanks guys
Tyson
Dec 24, 2010 12:37 AM
PreyStayShun
Dec 6, 2008 11:34 PM
LivinDreamsEK9
Feb 26, 2007 08:17 PM
DA808TWITCH
Oct 20, 2005 03:41 PM
hondacivichatch
Aug 17, 2005 07:35 AM
