question on offsets????????????
trying to figure out what offset to use on a 95 teg so that the rear tires are almost touching the fender. I wanna put the rota gt3's on wich are 7" wide with a 205 tire.
for comparison... 16x7.5" +40 offset 215/45 azenis. lowered 1.3" eibach prokit. rear would rub with lip liners. removed the liners and there is no rub.
hth
hth
that's about what i want is a pinky finger size gap between the tire and the fender. I really want them to fill up the wheel well. you think that a 16" by 7" will do that with a 205/45/16.
YEAH Stick with the 205s tho any wider and youll prolly have rubbing problems all this assuming you are aligned you can fit a 215 easy if not but they will wear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg95 »</TD></TR><TR><TD CLASS="quote">trying to figure out what offset to use on a 95 teg so that the rear tires are almost touching the fender. I wanna put the rota gt3's on wich are 7" wide with a 205 tire.</TD></TR></TABLE>
You should see HeyMikey's red teg w/ 195/50-15 tires and old school 15x7 Enkei mesh wheels with +20 offset and rolled fenders, now that looks bad@$$, the fenders are about as full as they can possibly get.
his teg is badass, I was wondering what wheels they were, that's what I want mine to look like but with out rolling the fenders.
mamaboy
May 6, 2003 03:23 PM
