Question on LS/VTEC conversion kit
Old Dec 9, 2007 | 07:21 PM
  #26
mcyang87's Avatar
is p28 better then like b16 or b18 ecu? don't that p28 have to be chipped?
Old Dec 9, 2007 | 10:36 PM
  #27
Mfoehrkolb's Avatar
obd1 p28 with step down (deping on your car year). will plug and play. If you look up ls.vtec builds, they say the b series vtec stock ecu tends to give the car a rouge idle, and some other minor problems and if you get p28 obd1, you can get it chipped as well. Me and all my friends use p28's on the ls.vtec builds and always worked wonders.
Old Dec 10, 2007 | 06:44 AM
  #28
mcyang87's Avatar
ahhh i see...it a good thing p28 is obd1 cause i have a 94 integra :D
Old Dec 10, 2007 | 08:26 AM
  #29
K2sInteg98's Avatar
Default Re: (mcyang87)
yup, you will just have to get it chipped and tuned for your car because a p28 is a single cam vtec ecu, you need it to be tuned to your dohc vtec
Old Dec 10, 2007 | 10:26 AM
  #30
Mfoehrkolb's Avatar
Default Re: (K2sInteg98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2sInteg98 &raquo;</TD></TR><TR><TD CLASS="quote">yup, you will just have to get it chipped and tuned for your car because a p28 is a single cam vtec ecu, you need it to be tuned to your dohc vtec</TD></TR></TABLE>
--- Yeah, Mcyang87. Don't misconstrue what im saying. You will still need to get it chipped, just p28 runs better till you do.
Old Dec 10, 2007 | 08:54 PM
  #31
mcyang87's Avatar
alright i remember to get it chipped thanks
Old Dec 10, 2007 | 09:27 PM
  #32
R.A.T.'s Avatar
if you build an ls-vetc make sure you build it the right way!
Don't do a half *** job as you said that you don't have enough funds to build. Trust me if you don't build it right from the beginning it will cost you more later on! Better be patient and save up to do the build.
If you purchase the golden eagle kit, ditch the gasket and purchase an OEM LS
Make sure you get ARP rod bolts and Head studs, new oil pump, water pump 22t and timing belt, then you'll need a good tune on a P28
Here is a link that you should read and re-read to make sure you get this done right:
https://honda-tech.com/zerothread?id=1676914
Old Dec 11, 2007 | 07:17 AM
  #33
mcyang87's Avatar
is the golden eagle head gasket that bad then to OEM LS?
Old Dec 11, 2007 | 08:17 AM
  #34
R.A.T.'s Avatar
It's not bad, it's just not the right one. The one they supply you with is for a vtec engine. Your block is still the LS so you must get the OEM LS Gasket or else it will leak.
Old Dec 11, 2007 | 11:28 AM
  #35
mcyang87's Avatar
ahh i see...so im better off buying the head bolt, stud, conversion kit without the headgasket then
Old Dec 11, 2007 | 11:44 AM
  #36
mcyang87's Avatar
i visit some of the website that has ls/vtec conversion kit..they ask if it 81mm bore which is stock ls block would that work too?
Old Dec 11, 2007 | 12:10 PM
  #37
NAmodified's Avatar
so if i go with a lsv set up and i change all the internals to itr!!! i will have a type r with a bigger displacement correct?
also i heard a golden eagle kit will have a greater vtec kick due to the fact that there is more pressure and oil going to the head.
compared to the small oil hole on the block that is used for vtec
Old Dec 11, 2007 | 12:24 PM
  #38
mcyang87's Avatar
well the internal that im getting with the head is already been done by Skunk2...ahhh so the golden eagle kit is pretty good then
Old Dec 11, 2007 | 02:47 PM
  #39
R.A.T.'s Avatar
Default Re: (NAmodified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">so if i go with a lsv set up and i change all the internals to itr!!! i will have a type r with a bigger displacement correct?
compared to the small oil hole on the block that is used for vtec</TD></TR></TABLE>
Not too sure about the bigger displacement, maybe more compression but if you stick to stock bores your displacement will be the same.
Someone correct me if I'm wrong on this one.
And about more pressure... alot of people add catch cans and engine breathers to release the pressure. Pressure can damage equipment prematurely.
Old Dec 11, 2007 | 05:51 PM
  #40
mcyang87's Avatar
ahh i c
Old Dec 11, 2007 | 07:29 PM
  #41
Mfoehrkolb's Avatar
the bore isn't the only factor in discplacement size. your the length of your connecting rods, your crank, your pistons all have a factor. the LS's displcament is the largest out of the b18c5 and c1. it has the longest stroke and lowest comp pistons. so it has like 75cc more.
Old Dec 11, 2007 | 07:30 PM
  #42
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by &raquo;</TD></TR><TR><TD CLASS="quote">
B18B1
* Non-VTEC
* Found in:
o 1994-2001 Acura Integra "RS/LS/GS" (DC4/DB7)
+ Displacement: 1834 cc
+ Compression: 9.2:1
+ Bore: 81 mm
+ Stroke: 89 mm
B18C1
* VTEC
* Found in:
o 1994-2001 Honda/Acura Integra GS-R (DC2 & DB8)
* Displacement: 1797 cm³
* Compression: 10.0:1
* Bore: 81 mm (3.189")
* Stroke: 87.2 mm (3.433")
* Rod Length: 137.9 mm (5.429")
* Rod/Stroke Ratio: 1.58
Old Dec 11, 2007 | 08:31 PM
  #43
mcyang87's Avatar
so when i go to order the ls/vtec conversion kit...do i put down 81mm bore or 82mm bore?
Old Dec 12, 2007 | 04:27 AM
  #44
Mfoehrkolb's Avatar
81 bore LS head gasket.
Old Dec 12, 2007 | 05:44 AM
  #45
R.A.T.'s Avatar
Thanks for clearing that up. But what would be the point to change all the internals if you go LS/Vtec? Might as well just do a ITR swap. The LS/Vtec is stronger on the low end with it's rod length making quicker than an ITR and GSR.
Old Dec 12, 2007 | 07:36 AM
  #46
mcyang87's Avatar
ahhh i guess ls/vtec has it up and down then
Old Dec 12, 2007 | 08:10 AM
  #47
mcyang87's Avatar
which head is better to fun ls/vtec? GSR or B16 head?
Old Dec 12, 2007 | 11:56 AM
  #48
OSK Automotive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcyang87 &raquo;</TD></TR><TR><TD CLASS="quote">which head is better to fun ls/vtec? GSR or B16 head?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.A.T. &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1676914</TD></TR></TABLE>
Follow that link. There's a good explanation on the pros and cons to both under "The Head". I would personally go with the b16 head but that's me.
Old Dec 12, 2007 | 12:25 PM
  #49
mcyang87's Avatar
alright i head b16 head i give you a better top end is that correct?
Old Dec 12, 2007 | 08:36 PM
  #50
mcyang87's Avatar
i was thinking would a type r head be better then b16 head?
