Question about test pipe
Old Mar 2, 2004 | 02:17 PM
RAS Motorsports's Avatar
Default Question about test pipe
I'm about to buy a test pipe from this guy on H-T. I have a 95 gsr...and the pipe is from a ITR...it is 17.5" long and 2.5" inlet and outlet. I have a JDM dc 4-1 header goin into a complete n1 cat-back...will this test pipe fit?
https://honda-tech.com/zerothread?id=784679
Old Mar 2, 2004 | 03:02 PM
IN VTEC's Avatar
Default Re: Question about test pipe (95GeeZR)
Probably not unless you shorten the b-pipe a little.
Get under the car and measure the cat from flange to flange.
Old Mar 2, 2004 | 03:17 PM
Default Re: Question about test pipe (IN VTEC)
nobody knows the exact measurements already? dats y i posted so i didn't have to try to calculate it myself and maybe mess up...
Old Mar 2, 2004 | 03:33 PM
IN VTEC's Avatar
You're not calculating it. You're measuring it directly. You can't mess it up.
Old Mar 2, 2004 | 03:36 PM
acually...i dont have the header or exhaust on it right now...and my setup right now is ghettofied...so...does anybody have the measurement?
Old Mar 2, 2004 | 04:28 PM
93civic_sedan's Avatar
A buddy of mine has an Ls motor in his CRX. I know its a little different but he had to have alot trimmed off his testpipe (appx. 6inches). He has OBX-R cat-back with some cheap *** header.
Old Mar 2, 2004 | 04:35 PM
kNOwLedGeDA9
Guest
Posts: n/a
If its not the right lenght cut an weld. Its soooo easy. You could make your own test pipe. All you need is a $25 2.5" header flange, $5 for 18" of 2.5" pipe from pep boys, and another flange that bolts to your exhaust. AND YOURE DONE...once you cut it to length and weld it together.
Old Mar 2, 2004 | 04:46 PM
p1ccoloz's Avatar
Default Re: (kNOwLedGeDA9)
itr wont bolt on directly, i have a testpipe for sale if you want for tha 95 gs-r
Old Mar 2, 2004 | 05:46 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 &raquo;</TD></TR><TR><TD CLASS="quote">If its not the right lenght cut an weld. Its soooo easy. You could make your own test pipe. All you need is a $25 2.5" header flange, $5 for 18" of 2.5" pipe from pep boys, and another flange that bolts to your exhaust. AND YOURE DONE...once you cut it to length and weld it together.</TD></TR></TABLE>
$25 for a flange?
6 bucks per flange.. = 12
1 foot of piping= 7-10
making it yourself! priceless
Old Mar 2, 2004 | 07:37 PM
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">
$25 for a flange?
Uhhhh yeah. There is a certain flange you need to fit a 2.5" header collector. http://www.inlinefour.com charges $28, http://www.jhpusa.com sells it for $25. This is not a flange that just ANY place sells.
Old Mar 2, 2004 | 07:56 PM
IN VTEC's Avatar
You can just get a universal 2.5" ID 4.75" bolt-spaced 2-bolt flange, slip it over the end, and then flare the end of the pipe.
It gets you the same seal on the donut gasket for just the cost of the labor and a $6 flange.
Old Mar 2, 2004 | 09:52 PM
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (IN VTEC)
This is true. Then why would someone pay $50 for the stright pipe this dude is selling?
Old Mar 2, 2004 | 11:23 PM
KTeller8's Avatar
Uhhhh yeah. There is a certain flange you need to fit a 2.5" header collector. http://www.inlinefour.com charges $28, http://www.jhpusa.com sells it for $25. This is not a flange that just ANY place sells.</TD></TR></TABLE>
send us a link to that item. i dont see why it should be 25..
Old Mar 3, 2004 | 12:30 AM
ok..so the final conclusion is..it won't fit...exactly how long would i need it tho?
Old Mar 3, 2004 | 01:00 AM
96dc2's Avatar
Default Re: (95GeeZR)
Buy an LS/ITR exhaust. Otherwise you need a 12" cat.
Old Mar 3, 2004 | 07:51 AM
Default Re: (96dc2)
o...so if i ordered a complete n1 catback for an 94+ Integra LS or ITR i can use that test pipe?
Old Mar 3, 2004 | 08:50 AM
IN VTEC's Avatar
I've gotten the same flange before from inlinefour. It's a polished stainless piece that accepts the donut gasket, that's why it's so much.
http://www.inlinefour.com/25incolflan.html
You butt weld the 2.5" pipe to it.
I'm using one for a stainless race pipe. The mild steel race pipe I'm using for length tuning is gonna have a flared end and universal 2-bolt flange deal on it. Then it gets scrapped for other projects unless somebody buys it.
Old Mar 3, 2004 | 09:06 AM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GeeZR &raquo;</TD></TR><TR><TD CLASS="quote">o...so if i ordered a complete n1 catback for an 94+ Integra LS or ITR i can use that test pipe?</TD></TR></TABLE>
That's what I wrote.
Old Mar 3, 2004 | 10:35 AM
Default Re: (96dc2)
lolz ok...thnx
Azn Kenny
Sep 26, 2007 11:42 AM
92integracer
Dec 13, 2006 10:34 AM
DpQInteg
May 15, 2006 12:55 PM
TypeR714
Jun 5, 2002 05:51 AM
comptechgsr2000
Honda S2000
Apr 27, 2002 03:48 PM
