push button start.. please send info.
Old Oct 30, 2002 | 11:39 PM
95integragsr1984's Avatar
Default push button start.. please send info.
Hey i'd like to put a push button start on my 95 teg gsr ... ive seen some pictures of what i need and everything but i can figure out where the wires will go...
S2000 has 5 pins on back, and a guy told me that a old 4 pin connector from a PC FDD will connect to the pins, but i only need the first 3 pins all other pins, wires can be cut... theres 3 wires then i need to connect to stuff right? 1 to ground, 1 to battery? 1 to____? please help me out, sorry if i mad this sound confusing.or if im wrong about anything let me know. thanks
also once installed i wont need the key to start at all right , or how will that work?
Old Oct 31, 2002 | 06:44 AM
94TealGSR's Avatar
Default Re: push button start.. please send info. (95integragsr1984)
http://www.bseries.net/html/garage/s2kstartbutton.php
Hope that helps. Let me know how it goes btw. I'm thinking of doing the same.
If you're looking for a decent price on the part itself:
http://www.hondaautomotiveparts.com/...atcgry5=SWITCH
Switch Part No = 204652 ($32.62)
Bulb Part No = 204649 ($2.51)
Also, you still need the key to start. You put the key in and turn it to the "On" position, then hit the button. Just imagine how easily someone could steal your car if it didn't require a key. I'm sure you could figure a way to wire it so that you didn't need a key, but that's just a bad idea.
Let me know how it goes.
Thedarkonex
Jun 27, 2018 06:15 PM
d_EG COUPE
Feb 22, 2010 07:26 PM
soulassasincc
Apr 6, 2006 10:10 AM
rodvang
14
Nov 28, 2004 01:09 PM
Stellar1
Oct 17, 2003 01:49 AM
