pulls to right....
Old Feb 8, 2004 | 08:43 PM
MikeyDB7's Avatar
Default pulls to right....
For some reason..my car pulls to the right..
I currently have Tein SS coilovers and Ingalls Camber kit on a 94 Integra LS
my car is lowered only .5 inches lower than stock, and I just had a alignment and camber adjustment done to the car.
Its not the tire pressure because it was adjusted at the alignment shop.
My car was pulling to the right even before the alignment and camber adjustment.
And all 4 tires are brand new, 215/17/40z Dunlop SP sport, purchased at time of alignment
what else can this be? I just need to identify whatever parts can be the problem so my uncle can repair it.. he can't seem to find anything wrong..and hes a mechanic by trade.
cliff notes: car pulls right despite perfect alignment and camber adjustment, perfect tire pressure, new tires..
Old Feb 8, 2004 | 11:01 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: pulls to right.... (MikeyDB7)
Can't really think of anything, so here's an up for you.
Here are some stupid thoughts in my head that might mean something....
You are aware that in the USA, most all roads are constructed so that the car will drift to the right somewhat. It's safer (in case you fall asleep) and also for water runoff.
Also, was the car ever in an accident where the frame was damaged? That could be it as well.
Old Feb 8, 2004 | 11:06 PM
Dc2 Powered's Avatar
maybe a mis-alignment of the axles my frineds car does that also.. its kinda anoying i can't like let go of the wheel for even a sec i would have to hold it to straighten it out
Old Feb 8, 2004 | 11:14 PM
shamoo's Avatar
Default Re: (Speedin Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedin Type R &raquo;</TD></TR><TR><TD CLASS="quote">maybe a mis-alignment of the axles my frineds car does that also.. its kinda anoying i can't like let go of the wheel for even a sec i would have to hold it to straighten it out</TD></TR></TABLE>
How the heck do you misalign an axle? It only goes in one way. Even if it's not fully in, it'll pop out. Still won't mess up the steering of the car in any way. Oh well.
Original poster: Tie rods?
thaiphob's Avatar
Nikon!!!
Default Re: pulls to right.... (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Can't really think of anything, so here's an up for you.
Also, was the car ever in an accident where the frame was damaged? That could be it as well.</TD></TR></TABLE>
actually this is correct.
Old Feb 8, 2004 | 11:43 PM
Default Re: (shamoo)
Original poster: Tie rods? </TD></TR></TABLE>
haha i don't think i ment to say axle.. maybe misalign steering wheel? iono.. but i have the same prop. so if you figure it out. holla.
Old Feb 9, 2004 | 12:35 AM
MikeyDB7's Avatar
my car was bought brand new back in 94.... so no.. its never been in an accident.
I dunno.. might be the tie rods.. if all else fails.. I'll just go get *** rammed by the Acura dealer technicians..hopefully they can solve the problem
I hate driving like this..the car feels so unstable..bump thanks for the advice though guys..anyone else?
Old Feb 9, 2004 | 08:30 AM
yellow_jacket's Avatar
Default Re: (MikeyDB7)
Swap the front left and front right tires. Did they give you a printout of the numbers from when they did an alignment?
Also, did you do a 4 wheel or 2 wheel? If you only did 2 there is a chance the rear is off and causing the car to pull a little.
Old Feb 9, 2004 | 08:47 AM
kaboomin's Avatar
same thing was happening to me, brought it to the dealership and turned out to be a bent control arm. . .
Old Feb 9, 2004 | 09:02 PM
MikeyDB7's Avatar
Default Re: pulls to right.... (kaboomin)
hmm good advice guys..
btw how much is it to replace say a control arm ? at the dealership?
Old Feb 9, 2004 | 09:25 PM
inzaneN1's Avatar
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
have u checked and made sure that ur coilovers are even my car was pulling to the right couple of days ago till i adjusted my coilovers
Old Feb 9, 2004 | 09:32 PM
crazzeboost's Avatar
I got a used control arm from a junk yard, check that first, like a pick and pull or call around.
Old Feb 9, 2004 | 09:42 PM
migs's Avatar
What is your camber specs AFTER the alignment was done?
Old Feb 9, 2004 | 10:24 PM
Sukebei Oni's Avatar
Default Re: (Migs)
first of all, how long ago did you install the teins? are you sure the car is sitting level? did you get a print out of the alignment specs, before and after? what were they. Is there any damage to your wheels? maybe its a tire pull. try rotating the tires before you change the LCA. even though they are new, the tires could still be defective.
Old Feb 10, 2004 | 12:51 PM
MikeyDB7's Avatar
Default Re: (Sukebei Oni)
bump thanks guys..lemme check those coilovers, I did raise them back up after the alignment and camber adjustment..
Old Feb 10, 2004 | 12:57 PM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeyDB7 &raquo;</TD></TR><TR><TD CLASS="quote">bump thanks guys..lemme check those coilovers, I did raise them back up after the alignment and camber adjustment.. </TD></TR></TABLE>
Now you just completely changed the alignment.
ANYTIME you SLIGHTLY move the coilovers up or down, you ruin the alignment.
Make sure car is level, align rear, re-align front.
Was it pulling BEFORE the suspension install?
Old Feb 10, 2004 | 01:13 PM
TurboedGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeyDB7 &raquo;</TD></TR><TR><TD CLASS="quote">I dunno.. might be the tie rods..</TD></TR></TABLE>
the tie rods wouldnt make it constantly pull to one side. it would only pull (either way) on unlevel road.
Old Feb 10, 2004 | 02:22 PM
xteg95's Avatar
Default Re: (Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris &raquo;</TD></TR><TR><TD CLASS="quote">
Was it pulling BEFORE the suspension install?</TD></TR></TABLE>
yea why would you get an alignment and THEN adjust your coils?
Old Feb 10, 2004 | 04:17 PM
Default Re: (TurboedGSR)
Just so you know, tie rod ends (which adjust the front toe) don't cause a pull in most situation. they would only cause the steering wheel not to be centered.
ex:
If when your steering wheel is centered, and the left toe is 0.00, and the right toe is 0.50. Then when driving down a flat road and you let go of the wheel, the left and right side would counter each other and find an equal setting. such as 0.25 for the left, and 0.25 for the right. when the wheels centered them selves in this way, it would cause the steering wheel to be off to the right a bit from center. Although the car might be rolling strait now, this would eat up the tires.
Jimmydean771
May 20, 2014 05:49 PM
Coopa B18c5
Jan 18, 2013 07:58 PM
doodooheadfart
Suspension & Brakes
Jan 16, 2006 09:01 AM
spencedogg
Dec 5, 2003 05:25 PM
eTec
Apr 17, 2002 08:22 PM
