problems shifting
I just noticed this today..w.hen I shift 2nd to 3rd...its a lil tough...like i gotta shove it into the gear...3rd to 4th is okay..not as bad...but it happens only sumtimes...what can i do to resolve thiss??
change tranny oil??
change tranny oil??
do you still have stock shifter? or was it touched at all. the bolt to your shifter might be too tight for the bearings in the shifter not to move enough.
also, there might be crap on the ball on the shifter, clean it and lube it up y0
stock shifter....so take the shifter out...clean the ball....put back in..change oil...??
anybody know hwoto remove the shifter to get access to the ball..
jack up ur car....unbolt the exhaust....then unbolt the shifter linkage...once u see it it's very elementary...easy ****...while ur at it replace it w a skunk2 short shifter and some ES bushings...u'll be happy...and change ur tranny oil too...bout 2.5-2.7 qts of honda mtl...
time for new tranny fluid....mine is starting to feel rough through all my gears! shitty, but i got the redline mtl here ready to go!
k actually it might be my clutch now...how do you know when your clutch is gonan go?
right now...i got the same problems while car is in motion...smooth as a baby when its idled...switching gears while in motion is a lil tough as mentioned above....BUT however...i noticed as I'm driving and then I lert it cruise....whiel the rpm drops...I would be in first gear and it'll start to make actions like it wants to stall...could this be a bad clutch and not holding on?? and also when i step into the clutch..its qutie stiff...it was liek this before i bought it...could it be the clutch?? I'm sorta thinking it is now...
bad clutch not holding on?? that makes no sense. maybe SLIPPING, if your shifter is making actions then your synchros might be wearing out.
you know ur clutch is going out when it starts slipping, or the springs in the clutch break, or what not. your clutch goes when YOU don't go anymore because there is no contact between the transmission and the flywheel (to the motor).
it's something with your shifter, shift linkage or internals in the tranny. take advice from above and see how that works for ya
I will gurentee it has nothing to due with your shift lever. It is a bad syncro or syncro caseing. They wear out and make it though to get into gear and it doesnt have to grind to mean its bad. The reason its nothing to do with the shift linkage is because you said the other gears work fine. If they work fine, they why would it only need cleaning for one gear? Also, when you shift...there is a lot or torque put on the lever. You are not going to feel a bad bearing in there and last; civic shifters dont even come with a bearing in there.........Mike
try changing the tranny fluid.. its worth a try, doesnt cost that much and good for your tranny anyway especially if its due for a change... then if that doesnt solve it.. work from there..
Thanx for your help guys...I'm gonna change the tranny fluid first and then go from there...if that dun work and its the synchros goign bad...aaiyahhh....i'm gonna cry..LOL...
Civic ends are smaller then integras and do not have a bearing setup in them.
slash00R
Nov 1, 2004 07:23 PM
CrX-To-Tha-Max
Mar 17, 2004 11:10 AM
