Problems with my DA...
Old Sep 30, 2004 | 10:42 PM
808jdm_gsr's Avatar
Default Problems with my DA...
I have a DA, Well the problem is that whenever I start riding it starts to miss fire alot, and when I was driving on the highway I was going like about 60 right then I stop accelarating, so I had to down shift then up shift to get it to accell again. I got a fuel regulator, then I got the MSD cap w/ coil and then i got new wires and I'm still running crappy. I looked at my spark plugs and Oxy sensor and they were total black. What do you guys think could be wrong?
Modified by 808jdm_gsr at 7:59 AM 10/1/2004
Old Sep 30, 2004 | 11:39 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: Problems with my DA... (808jdm_gsr)
Hmm...sounds kinda like a distributor problem. Try borrowing someone elses distributor for a second and see if that fixes it, but remember, 90-91 and 92-93 distributors are different.
Old Oct 1, 2004 | 12:06 AM
SwedBoy2999's Avatar
if you didn't replace the ignitor(spelling) then i would check that first. Mine just died while i was driving and it was either the coil or the ignitor, i replaced both since my car has 130,xxx miles on it. It worked fine after i did that.
Thats my advise take it or leave it.
In the helms manual it says how to test them i think.
Old Oct 4, 2004 | 03:01 AM
808jdm_gsr's Avatar
Fixed it...I'm a dumb **** the fuel pressure was way to high at like 50 psi. I didn't know you had to adjust it when the hose is off.
Old Oct 4, 2004 | 06:03 AM
mattcalica's Avatar
running too rich man...ur fouling out the plugs which is causing the misfire...
*edit*welp i guess you figured that out already
erik92DA
Jun 8, 2006 08:16 PM
Skank_aSS_Dara
Mar 24, 2005 09:21 AM
girlieracerk
Dec 18, 2003 10:12 PM
Jon5240
Oct 25, 2003 08:35 PM
FitCRX
Feb 3, 2003 07:13 PM
