Problems with J's Racing ECU program
Old Jul 10, 2003 | 09:42 AM
The Poopsmith's Avatar
Default Problems with J's Racing ECU program
I have a p28 ECU w/ a J's racing program in myu OBD2 GSR. I plugged in the ECU and the idle is erratic, it goes anywhere from 800 to 500 and sometimes dies. While I'm driving the car bogs alot under partial throttle. What could be the problem, the actual program or the install
Old Jul 10, 2003 | 09:52 AM
JDM CTR EK's Avatar
Default Re: Problems with J's Racing ECU program (DeeSeeToo)
where do you guys buy J's Racing products from?
Old Jul 10, 2003 | 09:57 AM
Default Re: Problems with J's Racing ECU program (JDM CTR EK)
come on mang, I got my ECU chipped from http://www.hyperducktuning.com, its not really from j's racing, just the program
Old Jul 10, 2003 | 10:35 AM
just read the archives and am going to try to unplug the evap solenoid
Old Jul 10, 2003 | 11:06 AM
up, evap didnt work, could somebody run down the procedure of switching form OBD2 p72 to OBD1 chipped p28
Old Jul 10, 2003 | 11:24 AM
PoW3l2BaN's Avatar
You do have the conversion harness right? I have a crazy startup idle on my chipped p72. You can just play with the idle screw on the TB to fix your idle, but make sure the car is a normal oper. temp. though. By the way, did you request for the DOHC program? You might have the SOHC proggy and thats why everything is all out of whack. I hope you have a skunk2 manifold too cause that ecu cant control the secondaries..
Old Jul 10, 2003 | 11:36 AM
Default Re: Problems with J's Racing ECU program (PoW3l2BaN)
yup, i'm installing the manifold this weekend, i just wanted to make sure the ECU works.
Here's what I've done so far
#1 - Unplug battery, Plug in OBD1 ECU results in surging idle and car stalling out
#2 - Unplug battery, unplug EVAP (top of GSR manifold correct?), plug in ECU results in surging idle
#3 - Same as #2, but after car is warmed up I drive it around the neighborhood for about 3-4mins results in same idle same bogging while driving.
Does anybody else have ideas? Would adjusting the idle screw fix the surging idle, or woud it just move the surging idle up a couple RPM?
Old Jul 10, 2003 | 02:08 PM
eg6ajk's Avatar
check your PM. or hit me up on my email
that should defintaly not happen, tried different chips???
it all should work without a problem, as it was tested and and worked fine on my car.
Old Jul 11, 2003 | 09:10 PM
Default Re: Problems with J's Racing ECU program (eg6ajk)
Could somebody post a run down for switching from OBD2 to OBD1. So far I have taken that you need to
1. Unplug Battery
2. Unplug EVAP solenoid
3. Plug in ECU
4. Start up car and let it warm up from cold start
5. enjoy OBD1
I have done everything except for #5
Old Jul 12, 2003 | 07:58 PM
u[
Old Jul 13, 2003 | 08:18 AM
ups
Old Jul 13, 2003 | 09:08 AM
pr0jektdc2's Avatar
free bump for you!
Old Jul 24, 2003 | 11:22 AM
update, switched in another chip, and still the same problem. Did all the steps, jesus christ did anybody else have this much problem switching to OBD1?
I have a VAFC installed, could that be the culprit?
KiNGDEE206
Engine Management and Tuning
Aug 29, 2016 08:58 AM
scott_turner
Aug 26, 2011 12:51 PM
97ek9
Jun 22, 2007 07:09 PM
mikeunreal2
31
Mar 12, 2006 10:28 PM
willyboyK20
Apr 11, 2005 04:43 PM
