problems with gsr
Old Mar 3, 2008 | 12:09 AM
accordin 2 me's Avatar
Default problems with gsr
ok so i have a 97 ls shell, i just finished installing a 99 gsr motor, tranny, and ecu, i have a check engine light but i dont know what codes are thrown yea all i do know is that i cant rev past 5000. it feels almost like 2 step but im pretty sure limp mode is at 3k rpm... someone pleaseeeeeeee help.... i used the 99 gsr harness do i need to run additional wires for vtec? is this why i cant rev past 5k
Old Mar 3, 2008 | 09:48 AM
bump, gas gauge also dosent work but its also from a gsr
Old Mar 3, 2008 | 10:28 AM
thevtecnician's Avatar
Default Re: problems with gsr (accordin 2 me)
You should really check your ecu codes. Its probably a very simple sensor that is malfunctioning/plugged into the wrong hole. I'm not sure of the harness because your car is obd2a and the harness I believe is obd2b but I could be wrong. Someone will chime in
Old Mar 3, 2008 | 12:52 PM
there both obd2a the ecu plugged straight in
Old Mar 5, 2008 | 01:10 PM
vshavoc's Avatar
Default Re: (accordin 2 me)
Yeah but the chassis harness is for a ls not a gsr. You need to run the extra plugs for the vtec. Did you notice that you had extra plugs from the gsr harness that didn't have a place to be plugged into on the ls chassis harness? I did the same swap and had the same issue. Also I changed the cluster and had the same problem. You probably gotta swap the green film on the back of the cluster to make it work right.
deguzmanEG
Jul 1, 2012 12:46 PM
boosted20psi
May 20, 2012 03:03 PM
CA6VTEC
May 31, 2010 02:46 PM
LS_DON4500
Jun 28, 2005 01:38 PM
SpoonyGSR
Jan 28, 2004 03:11 AM
